Geoform- Required Field
4279
04-13-2016 02:02 PM
RickeyFight
MVP Regular Contributor
I cannot figure out how to make a field required.
I know that at one point I was able to require a field before the form could be submitted but I cannot find that option now.
KellyGerrow
Esri Alum
Hi Rickey,
In order to create a required field, your feature service will need to have fields where nullable is set to false. You can set fields to be required before publishing your data in ArcMap and ArcGIS Pro.
Let us know how you are publishing your feature service if you need help setting this value.
-Kelly
KellyGerrow
Esri Alum
Hi Rickey,
-Kelly
RickeyFight
That is one option I thought would work.
Thank you for your Help!
