How to make a query from selection??
2728
04-14-2016 01:10 AM
JanPohle
Hey Everyone,
I need your help. It´s about VB.net. How can I make a new query from already selected Features?
So far I managed to fill a listbox with the information of the first categorie (e.g. State). Now I want to click on one of the categories to fill another listbox with information about the second categorie (e.g. Postcode). The Table is the same. It just needs to change the row and fill the second listbox. How do I get that?
I´m new to programming with VB.net so please explain as simple as possible! 😉
Thanks for your help!!
Public Sub New()
        InitializeComponent()
        Dim pTable As ITable
        Dim intLayer As Integer
        pMxDoc = My.ArcMap.Application.Document
        pMap = pMxDoc.FocusMap
        pActiveView = pMap
        intLayer = mod_state.findLayerByName("S6", pMap)
        If intLayer = -1 Then
            MsgBox("There is no layer!")
            Exit Sub
        End If
        pFeatureLayer = pMap.Layer(intLayer)
        pTable = pFeatureLayer
        Dim pTableSort As ITableSort = New TableSort
        With pTableSort
            .Table = pTable
            .Fields = "state"
            .Ascending("state") = True
            .CaseSensitive("state") = True
End With
        pTableSort.Sort(Nothing)
   pCursor = pTableSort.Rows
        Dim pRow As IRow
        pRow = pCursor.NextRow
        Dim strState As String
        strState = ""
        Me.lst_state_ID.Items.Clear()
        Do While Not pRow Is Nothing
            If (pRow.Value(22) <> strstrState) Then
             strState = pRow.Value(22)
                Me.lst_KAT_ID.Items.Add(strState)
            End If
        Loop
End Sub
Private Sub lst_state_ID_Click(sender As System.Object, e As System.EventArgs) Handles lst_state_ID.Click
        Dim pActiveView As IActiveView
        Dim pFeatureSelection As IFeatureSelection
        Dim pQueryFilter As IQueryFilter
        pActiveView = pMap
            MsgBox("There is no Layer!")
            Exit Sub
        End If
        pFeatureSelection = pFeatureLayer
       pQueryFilter = New QueryFilter
        pQueryFilter.WhereClause = "State = '" & Me.lst_state_ID.SelectedItem &  "'"
        pFeatureSelection.Clear()
        pFeatureSelection.SelectFeatures(pQueryFilter, esriSelectionResultEnum.esriSelectionResultNew, False
        pActiveView.Refresh()
    End Sub
WesMiller
You may want to move your question to the Developers​ group
KenBuja
MVP Esteemed Contributor
In the SelectFeatures method, you have the choice of esriSelectionResultEnum ​to use. Currently, you're using esriSelectionResultNew, but to select from the current selection, you have to use esriSelectionResultAnd
