set PictureMarkerSymbol to map
8368
10
04-13-2016 11:47 PM
CloudingSoft
Hello
I have multiple x and y coordinates, how I do to display in a map using PictureMarkerSymbol
applying this example:http://developers.arcgis.com/javascript/samples/playground/main.html#/config=symbols/PictureMarkerSy...
He does not tell me how to put the images on the map
Thank you
Tags (1)
CloudingSoft
good in the end I solved it with jQuery, I could not understand it well with dojo.
also thanks to your help I could add dynamic points to my map.
the solution with jquery:
var chks = $('.choferes');
for (var i = 0; i < chks.length; i++) {
   idButtonDojo = chks[i].value;
   var newButton = 'ButtonNodeAddMark_'+idButtonDojo;
   $( "#"+newButton ).on( "click", {
   y : $('#cho_y_'+idButtonDojo).attr("value"),
   x : $('#cho_x_'+idButtonDojo).attr("value"),
   nombre : $('#cho_nombre_'+idButtonDojo).attr("value"),
   direccion : $('#cho_direccion_'+idButtonDojo).attr("value"),
   telefono : $('#cho_telefono_'+idButtonDojo).attr("value"),
   color : "Blue"
}, addDinamicMark );
CloudingSoft
I could do so but does not show me the image on the map
I am minding X and Y
<!DOCTYPE html>
<html>
  <head>
    <title>Select with feature layer</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding: 0;
        margin: 0;
        height: 100%;
      #messages{
        background-color: #fff;
        box-shadow: 0 0 5px #888;
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
    </style>
    <script src="https://js.arcgis.com/3.16/"></script>
    <script>
       require([
                "esri/map",
                "esri/dijit/HomeButton",
                "esri/symbols/PictureMarkerSymbol",
                "esri/geometry/webMercatorUtils"],
                    function (Map, HomeButton, PictureMarkerSymbol,webMercatorUtils) {
                        var map = new Map("mapDiv", {
                            center: [-58.791635351999616,-34.60544583699959], // lon, lat  OK CENTER MAP
                            zoom: 6,
                            basemap: "gray"});
                        var home = new HomeButton({
                            map: map
                        }, "HomeButton");
                        home.startup();
                        dojo.connect(map, 'onLoad', function (map) {
                                                            lngLatToXY = webMercatorUtils.lngLatToXY(-58.791635351999616,-34.60544583699959);
//NO DRAW SYMBOL
                                nodalas(parseFloat(lngLatToXY[0]),parseFloat(lngLatToXY[1]));
                        function nodalas(x,y) {
                            var rigaSymbol = new esri.symbol.PictureMarkerSymbol("http://raimondsverpejs.lv/images/2015/06/lgia_riga.png", 39, 40);
                            var lgiaTemplate = new esri.InfoTemplate("${Name}", "<i><font color='grey'>Adrese:</font></i> ${Adrese}<br /><i><font color='grey'>Kontakti:</font></i> ${Kontakti}<br /><i><font color='grey'>Klientu pieņemšanas laiki:</font></i> ${Darbs}");
                            var nodala1 = new esri.Graphic({"geometry": {"x": x, "y": y, "spatialReference": {"wkid": 4326}}, "attributes": {
                                    "Name": "Parada 1",
                                    "Adrese": "<br/><b>Uriarte 100</b>",
                                    "Kontakti": "<br/><b>Tel.: 28655590, <br/>Fakss: 29370505, <br/>Mob.tel.: 26458270</b>",
                                    "Darbs": "<br/><b>HOrarios: 9.00 - 16.00</b>"}});
                            nodala1.setSymbol(rigaSymbol);
                            nodala1.setInfoTemplate(lgiaTemplate);
                            map.graphics.add(nodala1);
                            map.infoWindow.resize(270, 350);
    </script>
  </head>
  <body>
    <span id="messages">Click on the map to select census block points within 1 mile.</span>
    <div id="mapDiv"></div>
  </body>
</html>
RobertScheitlin__GISP
Fabien,
  Here is your code working with out mixing Legacy and AMD style coding.
Legacy style will be unsupported in the JS API 4.0 so you should not code using legacy anymore.
The abc’s of AMD | ArcGIS Blog
<!DOCTYPE html>
<html>
<head>
    <link rel="stylesheet" href="http://js.arcgis.com/3.16/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.16/esri/css/esri.css">
    <style>
        html,
        body,
        #mapDiv {
            padding: 0;
            margin: 0;
            height: 100%;
        #messages {
            font-size: 1.1em;
            max-width: 15em;
            padding: 0.5em;
            position: absolute;
            right: 20px;
            top: 20px;
            z-index: 40;
        #HomeButton {
            position: absolute;
            top: 95px;
            left: 20px;
            z-index: 50;
        </style>
    <script src="http://js.arcgis.com/3.16/"></script>
    <script>
        require([
                "esri/map",
                "esri/geometry/webMercatorUtils",
                "dojo/on",
                "esri/graphic",
                "esri/InfoTemplate",
                "esri/geometry/Point",
                "esri/SpatialReference"
            function(Map, HomeButton, PictureMarkerSymbol, webMercatorUtils, on, Graphic, InfoTemplate, Point, SpatialReference) {
                    center: [-58.791635351999616, -34.60544583699959], // lon, lat  OK CENTER MAP
                    zoom: 6,
                    basemap: "gray"
                    map: map
                }, "HomeButton");
                home.startup();
                on(map, 'load', function(map) {
                    var mapPnt = new Point(-58.791635351999616, -34.60544583699959, new SpatialReference({wkid:4326}));
                    nodalas(webMercatorUtils.geographicToWebMercator(mapPnt));
                function nodalas(pnt) {
                    var rigaSymbol = new PictureMarkerSymbol("http://raimondsverpejs.lv/images/2015/06/lgia_riga.png", 39, 40);
                    var lgiaTemplate = new InfoTemplate("${Name}",
                    var nodala1 = new Graphic(
                        pnt,
                        rigaSymbol,
                            "Name": "Parada 1",
                        lgiaTemplate);
    </script>
</head>
<body class="tundra">
    <div id="mapDiv"><div id="HomeButton"></div>
    </div>
</body>
</html>
CloudingSoft
excelent!
now, how add parameter's to method addDinamicMark???
function addDinamicMark(y,x,nombre,direccion,telefono,color) {
                    var mapPnt = new Point(y,x, new SpatialReference({wkid:4326}));
                    _width=_height=50;
                    setMark(webMercatorUtils.geographicToWebMercator(mapPnt),nombre,direccion,telefono,color,_width,_height);
                 * how add parameter's????
                on(registry.byId('DINAMIC_ButtonNodeAddMark'), "click", addDinamicMark);
                function setMark(pnt,nombre,direccion,telefono,color,_width,_height) {
                    var Symbol = new PictureMarkerSymbol("https://static.arcgis.com/images/Symbols/Shapes/"+color+"Pin1LargeB.png",_width,_height);
                    var Template = new InfoTemplate("${Nombre}","<i><font color='grey'>Dirección:</font></i> ${Direccion}<br />\n\
        <i><font color='grey'>Telefono:</font></i> ${Contacto}<br />");
                    var mark = new Graphic(
                        pnt,
                        Symbol,
                            "Nombre": nombre,
                            "Direccion": "<br/>"+direccion,
                            "Contacto": "<br/>"+telefono
                        Template);
                    map.graphics.add(mark);
addDinamicMark
Fabien,
Where is the "y,x,nombre,direccion,telefono,color" data coming from, form elements or what?
If they are coming from a form then something like this:
on(registry.byId('DINAMIC_ButtonNodeAddMark'), "click", function(){
    var y = registry.byId('yTB').get("value"),
    x = registry.byId('xTB').get("value"),
    nombre = registry.byId('nombreTB').get("value"),
    direccion = registry.byId('direccionTB').get("value"),
    telefono = registry.byId('telefonoTB').get("value"),
    color = registry.byId('colorTB').get("value");
    addDinamicMark(y, x, nombre, direccion, telefono, color)
CloudingSoft
ok, but always takes the latest data.
if I have the id buttons: ButtonNodeAddMark_8 and ButtonNodeAddMark_10
when I click the button ButtonNodeAddMark_8 ButtonNodeAddMark_10 data shows.
example:
click shows
-65.29711873399964
-24.19455872499958
depo co driver 2
Depos No. 2
Blue
should show
<Other data>
<Other data>
<Other data>
<Other data>
Blue
ButtonNodeAddMark_8
code:
                    idButtonDojo = chks.value; //first get id=8 and last get id=10
                    on(registry.byId(newButton),
                                        "click",
                                        function(){
                                            var y = $('#cho_y_'+idButtonDojo).attr("value");
                                            var x = $('#cho_x_'+idButtonDojo).attr("value");
                                            var nombre = $('#cho_nombre_'+idButtonDojo).attr("value");
                                            var direccion = $('#cho_direccion_'+idButtonDojo).attr("value");
                                            var telefono = $('#cho_telefono_'+idButtonDojo).attr("value");
                                            var color = "Blue";
                                            addDinamicMark(y, x, nombre, direccion, telefono, color,newButton);
Fabien,
Maybe show what your code looks like now as I am not understanding your workflow at all.
CloudingSoft
html
<!-- item 1 -->
<button id="ButtonNodeAddMark_8" value="8" data-dojo-type="dijit/form/Button" class="btnClass lista_choferes">Add Mark 8</button>
<input type="hidden" id="cho_nombre_8" value="chofer con depo 1" />
<input type="hidden" id="cho_email_8" value="dcdc@wjwj" />
<input type="hidden" id="cho_telefono_8" value="dcdc" />
<input type="hidden" id="cho_direccion_8" value="Depos n&ordm; 1" />
<input type="hidden" id="cho_y_8" value="-58.45888624899965" />
<input type="hidden" id="cho_x_8" value="-34.569560161999625" />
<!-- item 2 -->
<button id="ButtonNodeAddMark_10" value="10" data-dojo-type="dijit/form/Button" class="btnClass lista_choferes">Add Mark 10</button>
<input type="hidden" id="cho_nombre_10" value="chofer con depo 2" />
<input type="hidden" id="cho_email_10" value="dcdc@wjwj2" />
<input type="hidden" id="cho_telefono_10" value="dcdc2" />
<input type="hidden" id="cho_direccion_10" value="Depos n2" />
<input type="hidden" id="cho_y_10" value="-58.45888624899965 2" />
<input type="hidden" id="cho_x_10" value="-34.569560161999625 2" />
<script>
   require([
   "esri/map"
   "dojo/on"
   "dijit/registry",
   "dojo/parser",
   "esri/graphic"
   "esri/InfoTemplate"
   function(Map, HomeButton, PictureMarkerSymbol, webMercatorUtils, on,registry,parser, Graphic, InfoTemplate, Point, SpatialReference) {
  parser.parse();
   var map = new Map("map_camino", {
   zoom: 6
   basemap: "gray"
   "click",
   function(){
   var color = "Blue";
   function addDinamicMark(y,x,nombre,direccion,telefono,color,newButton) {
   console.log(y);
   console.log(x);
   console.log(nombre);
   console.log(direccion);
   console.log(telefono);
   console.log(color);
   console.log(newButton);
   _width=_height=50;
  pnt,
   Symbol
   "Nombre": nombre,
   Template);
  </script>
CloudingSoft
add checkbox 'choferes':
<input type="checkbox" name="chofer[]" class="choferes" id="chofer_8" value="8" attr_nombre="chofer 8" />
<input type="checkbox" name="chofer[]" class="choferes" id="chofer_10" value="10" attr_nombre="chofer 10" />
CloudingSoft
   color : "Blue"
