what value should be given to null field?
2513
04-08-2016 10:44 PM
VinayaD_Ccruz
Hello ,
I am having a data set with negative value for temperature. What value should be given to these fields so that my hot spot analysis calculation is not effected by these values.
DanPatterson_Retired
if you are using a point file/layer as input, it would be wiser, if you selected/queried for the valid data (ie not null) then export that to a separate layer...that would be the safest
