Script to Copy File in Modelbuilder
6851
11
04-08-2016 03:07 PM
ChrisHolmes
Hi all,
I have a very simple python script to copy a file from one location to another:
import shutil
shutil.copy("c:/chris/Test1/CitizenComments.mxd" , "c:/chris/test2/CitizenComments.mxd")
If I take this script and put it in a model builder model, what change would I have to make to the code so that I could have a parameter in the model where a user could enter an index string to be appended to the front of the file name?
Thanks!
Chrs
curtvprice
I suggest reading the help about how to set up input and output parameters to scripts.​ Once that is set up, you can right-click your script tool to expose its parameters in the model. The script needs to handle input and output parameters like this:
import arcpy
string = arcpy.GetParameterAsText(0)
import shutil
shutil.copy("c:/chris/Test1/CitizenComments.mxd",
            "c:/chris/test2/{}CitizenComments.mxd".format(string))
arcpy.SetParameterAsText(1,  "c:/chris/test2/{}CitizenComments.mxd".format(string)))
Then, set your script tool with an input parameter of type String and a derived parameter of type File. Then re-add your tool to ModelBuilder and I think you'll get what you're looking for.
Or, you can avoid having to set up a separate script tool by using the very useful Calculate Value model-only tool -- a little Python goes a long way in ModelBuilder! You can get this tool added to your model with a right click.
Expression:
CopyFile(r"%String%")
Code Block
import shutil
def CopyFile(string):
  return "c:/chris/test2/{}CitizenComments.mxd".format(string)
Data Type
File
Set your parameter String as type String and use the magic wand tool to make it a precondition to Calculate Value, and you're good to go!'
ChrisTool_tbx("Trump") will copy your map document to the path
C:\chris\test2\TrumpCitizenComments.mxd
ChrisHolmes
Oh ya, as you can tell: new to python
curtvprice
import arcpy
import shutil
Expression:
Code Block
import shutil
Data Type
File
ChrisHolmes
Thanks Curtis, I'll check this out.
Chris
ChrisHolmes
Thanks Curtis, following your advice I was able to get the copy file working using:
If I wanted to modify the code block to first create a folder with the same name as what is appended to the copied CitizenComments.mxd file what would need to be changed? So for example the new file path would be C:\chris\105\105CitizenComments.mxd
I had tried the following based on the previous copy file code, but obviously I'm missing some stuff:
import os
import shutil
   os.mkdir("c:/chris/{}.format(string))
                     "c:/chris/{}/{}CitizenComments.mxd".format(string))
   return "c:/chris/{}/{}CitizenComments.mxd".format(string)
curtvprice
This is how you use a value twice in a format string. The way to debug this kind of thing is to find a Python prompt (the one in ArcMap will do) and type stuff at it:
>>> "{} {}".format("foo")
  File "<stdin>", line 1, in <module>
IndexError: tuple index out of range
>>> "{} {}".format("foo", "foo")
'foo foo'
>>> "{} {}".format("foo", "bar")
'foo bar'
>>> "{0} {0}".format("foo")
'foo foo'
import os
import shutil
                     "c:/chris/{0}/{0}CitizenComments.mxd".format(string))
   return "c:/chris/{0}/{0}CitizenComments.mxd".format(string)
7.1. string — Common string operations — Python 2.7.11 documentation
This is really helpful guide to Python string formatting I have bookmarked:
mkaz.tech – Python String Format Cookbook
ChrisHolmes
Thanks again for the help Curtis, this is super. Also thanks for the link!
ChrisHolmes
So I have the above code working to copy multiple files, but it doesn't work to copy a file geodatabase. Any suggestions for how to do this?
Thanks very much for all the help,
Chris
curtvprice
either shutil.copytree() or arcpy.Copy_management() should work.
ChrisHolmes
Thanks Curtis!
I first tried arcpy.Copy_management() and was able to get it working but my efforts to get it to use the parameter so the destination could change based on the user input failed.
So then I tried shutil.copytree() and it looks like it works:
shutil.copytree("x:/GIS/LUAM/DEV/TEMPLATE/data_for_item.gdb","c:/chris/{0}/data_for_item.gdb".format(string))
Have a good weekend.
