Script to Copy File in Modelbuilder
8403
11
04-08-2016 03:07 PM
ChrisHolmes
Hi all,
I have a very simple python script to copy a file from one location to another:
import shutil
shutil.copy("c:/chris/Test1/CitizenComments.mxd" , "c:/chris/test2/CitizenComments.mxd")
If I take this script and put it in a model builder model, what change would I have to make to the code so that I could have a parameter in the model where a user could enter an index string to be appended to the front of the file name?
Thanks!
Chrs
DarrenWiens2
The most straightforward way would be something like the following, although you may run into trouble with /" (untested):
import shutil
index = arcpy.GetParameterAsText(0) # get the first input parameter entered into the tool dialog
shutil.copy("c:/chris/Test1/CitizenComments.mxd" , "c:/chris/test2/" + index + "CitizenComments.mxd")
To better work with paths, use os.path.join:
import shutil, os
shutil.copy("c:/chris/Test1/CitizenComments.mxd" , os.path.join("c:/chris/test2", index + "CitizenComments.mxd")
ChrisHolmes
Thanks Darren. I'll play around with your suggestions.
Have a good weekend.
Chris
