Image sizes when added via "media::image" column
2823
04-08-2016 05:07 PM
GarretDubois
In Survey123 when inserting an image into a row that is set as
an integer or decimal via the “media::image” column on the “survey” sheet, the
image appears large in the finished survey. Is there a way to make the image
appear smaller until you tap it to enlarge it, as you would when you insert the
image in the “image” column within the “choices” sheet when the row is defined
as “select one” or “select multiple” ?
The image is just a sort of hint to help the user
understand what the integer or decimal they measured is used for and what it
means when it falls within a specific range.
LorettaWinton1
Was this ever answered? I also have the same issue.
Lori
Survey123Jedi2023
I have the reverse question. I want to use the media::image in the choices tab and want the image to be larger. Maybe I'll use the survey tab, and you both can use the choices tab.
Have a spatial day.
