SpatialReference is changed when exporting tilecache with parameters
3675
04-07-2016 04:09 AM
LucianoRodríguez
Hi to everyone, and thanks in advance for the help.
I have an strange problem using v.10.2.5 of ArcGis-RunTIme-SDK-iOS. After reading the guides i've been able to export tile cache of one agstiledlayer using the following code:
//temp is an NSMutableArray containing NSNumbers... something like {@"1",@"2",@"3"...}
//self.geom is an instance of AGSEnvelope with WKID = 25830 and xmin,ymin,xmax and ymax initialized to the values of the envelope i want to cache.
params = [[AGSExportTileCacheParams alloc] initWithLevelsOfDetail:temp areaOfInterest:self.geom];
[task exportTileCacheWithParameters:params downloadFolderPath:exportedPath useExisting:NO status:^(AGSResumableTaskJobStatus status, NSDictionary *userInfo) {
     //UPDATE STATUS OF DOWNLOADED PERCENTAGE...
} completion:^(AGSLocalTiledLayer *localTiledLayer, NSError *error) {
     //localTiledLayer spatialReference WKID is 102100
The problem i have is that the localTiledLayer downloaded has a different spatialreference (102100) than the parameters i used to specify the download (25830). Why is this happening? Am i doing something wrong or is something not related with the client (iOS) side?
Thanks for your help,
YueWu1
by Esri Regular Contributor
Hi Luciano,
You cannot overwrite/change the default spatial reference when you execute an export tile cache. The reason is because all tiling schemes are associated with a certain spatial reference. Your data frame/dataset/layer's spatial reference must match the spatial reference of your tiling scheme in order for tiles to be created. Think tile cached as a image, that you cannot distort those predefined image into another spatial reference. For more information, you can read this online documentation:
What is map caching?—Documentation (10.3 and 10.3.1) | ArcGIS for Server
Normally, when we download the cache tile in Runtime iOS, we will define the AGSEnvelope to current mapView extent:
AGSEnvelope *extent = [self.mapView visibleAreaEnvelope];
If you want to download a tile cache in 25830, you must find a tile cache service that has same spatial reference 25830.
Hope this can help.
YueWu1
Hi Luciano,
Hope this can help.
