Newbie question VB.NET + ArcGISRuntime
2858
03-14-2016 08:59 PM
MarcHillman
I'm using MS VB 2015, and I have the Esri.ArcGISRuntime loaded as a reference.
How do I open an existing Shapefile? I just want to extract some data, but having real trouble getting started. Can't seem to find any tutorials for the simple stuff.
TIA
This is my code
Public Class Form1
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
    End Sub
    Private Async Sub OpenToolStripMenuItem_Click(sender As Object, e As EventArgs) Handles OpenToolStripMenuItem.Click
        Dim dialog As New OpenFileDialog()
        With dialog
            .Filter = "Shape|*.shp|All|*.*"
            If DialogResult.OK = .ShowDialog Then
                Dim myShapefileTable As Esri.ArcGISRuntime.Data.ShapefileTable = Await myShapefileTable.OpenAsync(dialog.FileName)
            End If
        End With
    End Sub
End Class
but I get warning "BC42025    Access of shared member, constant member, enum member or nested type through an instance; qualifying expression will not be evaluated."
MarcHillman
Fixed. Bit in red needs to be this.
            Dim myShapefileTable As Esri.ArcGISRuntime.Data.ShapefileTable = Await Esri.ArcGISRuntime.Data.ShapefileTable.OpenAsync(dialog.FileName)
AdrianWelsh
MVP Honored Contributor
Hi Marc,
Can you give a little more description on what you are wanting to do? Are you wanting to load a shapefile into an ArcMap session? Are you wanting to just have the shapefile loaded into your code so that you can do stuff with it later?
I believe you have to call the FeatureLayer object in order to grab the shapefile. You're right that there are not many examples online. Take a look at this for some tidbits:
Code Example - FeatureLayerViaShapefile
(scroll to the bottom/middle and click on the  VB.NET area to toggle it off of C#).
Or maybe you need to use the ShapefileWorkspaceFactory object to get the shapefile.
...new ESRI.ArcGIS.DataSourcesFile.ShapefileWorkspaceFactoryClass()
There is an example here:
ArcObjects 10 .NET SDK Help
(scroll to the bottom or middle to get past the C# code)
MarcHillman
I have edited my post to show the code. It uses a fragment of the example you quote. Can't seem to get the OpenAsync method to work.
I just want to extract some shape data and export it as KML. No maps used.
MarcHillman
