Modify widget label
3282
7
03-14-2016 06:39 AM
AdamSmith
Using WebApp builder 1.3, is it possible to modify one of the config files to change the Label on widgets once activated so i don't have to redownload it? If so, which config file and where does it sit? - New to this web app builder game.
RobertScheitlin__GISP
Adam,
Sure in the apps main config.json you can find the widget and there is a label property for each widget listed there.
Adam,
AdamSmith
Top stuff (as simple as that). Thanks Robert
Adam,
Don't forget to mark my reply as the correct answer.
DianeWhited
Is there a way I can add an image and link to the widget label also?
Thanks!
Diane
Diane,
   Your question has me confused. Widgets already have an icon/image.
DianeWhited
Robert,
See image below.  I have the layerlist widget open in the sidebar.  I would like to add image and link along side the label.
Hope this clarifies things.  Thanks,
Diane
Diane,
   That would take a good deal of code to customize that theme to allow for that.
