update cursor invalid sql statement
9462
17
03-11-2016 09:01 AM
BrianLomas
I'm new to python so forgive me if this seems like a dumb question... I work for the city and we get parcel information monthly from the county. Usually the data comes in a text file which I then put in an mdb. I'm trying to write some code to run an update our layers with the updated monthly information. Currently, I've just been trying to get a few fields to update  inside a 'test' file geodatabase but I'm stuck. I get the following error message with the following code. Any ideas?
XanderBakker
Esri Esteemed Contributor
You could use a dictionary with a list of values, in stead of a dictionary with a single field as value. This would require some changes in building the dictionary and the way the values are retrieved in the update cursor, but it can be done. If the code you tested was fast, it means that you don't have that many features to process. In that case it would not be a problem to create this larger dictionary (with lists as values).
DarrenWiens2
Not sure about the rest, but you don't have the same number of single and double quotes.
BrianLomas
Oops I forgot I corrected that one... When that is taken out I get the following error...
Runtime error
  File "<string>", line 9, in <module>
RuntimeError: An invalid SQL statement was used. [Parcel_092015COPY]
DarrenWiens2
Try building your SQL expression in a previous line, then printing it to confirm that it is what you think it is.
WesMiller
Have you tried doing this in model builder. Most everything you'll need should be in there and it will give you a head start if you need to do any coding.
What is ModelBuilder?—Help | ArcGIS for Desktop
BrianLomas
I thought about model builder but this will run for more than 10,000 features so I was worried about it being too slow. Although, I'm not too familiar with MB so I may be  wrong.
DanPatterson_Retired
are your fields really  situs and current_ow  or those supposed to be sites and current_row which I did a brain translation to until I looked again
BrianLomas
yea, 'situs' and 'current_ow' are actual field names.
just checking sometimes it is the little things...
WesMiller
10,000 features wouldn't be a problem. You could simply join the 2 tables then use field calculator.
