Create Map Tile Package - Cannot run python script
3724
03-09-2016 10:54 AM
VitorFranca
Hi folks,
Using ArcGIS version is 10.2.2, I am trying to use arcpy.CreateMapTilePackage_management() GP tool in the script bellow to automate production of a large quantity of map packages to be used in handheld devices. I can create packages using the menu - File > Share As > Tile Package, but can not put the script to work, neither using ArcMap Python window or IDLE. I get the same error message:
Runtime error
  File "<string>", line 14, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 7170, in CreateMapTilePackage
    raise e
RuntimeError: Object: Error in executing tool
Here is my script:
import arcpy, os
import arcpy.mapping
mxd = arcpy.mapping.MapDocument('CURRENT')
df = arcpy.mapping.ListDataFrames(mxd, "MSR") [0]
# Cursor
for row in arcpy.SearchCursor("T_LM_SETORES"):
  df.extent = row.SHAPE.extent # ajusta a extensao do dataframe a extensao do setor
  df.scale = df.scale * 1.1 # ajusta a escala para dar uma margem maior ao setor no mapa
  arcpy.RefreshActiveView()
  geocodigo =  row.getValue("cd_geocodigo")
  mxd.save()
  print("Saving map tile package for sector " + geocodigo)
  arcpy.CreateMapTilePackage_management( mxd, "ONLINE", r"G:\\BaseTerritorial\\Atendimentos\\2PP_CensoAgro\\MapTilePackages\\" + geocodigo + ".tpk", "JPEG", "19", "#", "Test map package generation", "tag1, tag2")
DanPatterson_Retired
can you format your code  Code Formatting... the basics++
... and use single \ if you are using raw notation not double... it gets messy
>>> x = r"G:\\BaseTerritorial\\Atendimentos\\2PP_CensoAgro\\MapTilePackages\\"
>>> x
'G:\\\\BaseTerritorial\\\\Atendimentos\\\\2PP_CensoAgro\\\\MapTilePackages\\\\'
VitorFranca
import arcpy, os
df = arcpy.mapping.ListDataFrames(mxd,"MSR") [0]
# Cursor
  mxd.save()
  arcpy.CreateMapTilePackage_management( mxd, "ONLINE", r"G:\BaseTerritorial\Atendimentos\2PP_CensoAgro\MapTilePackages\" + geocodigo + ".tpk", "JPEG", "19", "#", "Test map package generation", "tag1, tag2")
I would have expected a different error message since your file path ends in a backslash
>>> geocodigo = "x"
>>> x = r"G:\BaseTerritorial\Atendimentos\2PP_CensoAgro\MapTilePackages\" + geocodigo + ".tpk"
Traceback (  File "<interactive input>", line 1
SyntaxError: EOL while scanning string literal
>>> x = r"G:\BaseTerritorial\Atendimentos\2PP_CensoAgro\MapTilePackages" + "\\" + geocodigo + ".tpk"
