Limit combobox results to map extent
7666
12
03-07-2016 08:37 AM
StevenGraf1
I'm using this thread as the base for my python addin toolbar.How to populate Add-In Combo Box with attributes
I was wondering if it was possible to limit the field unique values to whats in the map extent. There are thousands of unique values which doesn't take long to populate the combobox but to help the end user I would like to limit those to what's in the map extent.
Here's my python code so far.  You select the specific layer, then it sorts and pushes the unique values to a combobox. Once you select a feature from the drop down, it selects and zooms to that feature.
import arcpy
import pythonaddins
class leveeLayerListSelector(object):
    """Implementation for LeveeSearch_addin.comboboxLayerList (ComboBox)"""
    def __init__(self):
        self.items = []
        self.editable = True
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWWWWWWWWWWWWWWWW'
        self.width = 'WWWWWW'
    def onEditChange(self, text):
        pass
    def onFocus(self, focused):
        if focused:
            self.mxd = arcpy.mapping.MapDocument('current')
            layers = arcpy.mapping.ListLayers(self.mxd)
            self.items = []
            for layer in layers:
                self.items.append(layer.name)
    def onEnter(self):
        pass
    def refresh(self):
        pass
    def onSelChange(self, selection):
        global fc
        fc = arcpy.mapping.ListLayers(self.mxd, selection)[0]
class leveeSystemSelector(object):
    """Implementation for LeveeSearch_addin.comboboxLeveeSystem (ComboBox)"""
    def __init__(self):
        self.items = []
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW'
        df = arcpy.mapping.ListDataFrames(self.mxd, "Layers") [0]
        arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", "System_Name = '" + selection + "'")
        df.zoomToSelectedFeatures()
        arcpy.RefreshActiveView()
        pass
        global layer
        layer = arcpy.mapping.ListLayers(self.mxd, fc)[0]
        self.items = []
        values = [row[0] for row in arcpy.da.SearchCursor(layer, ["System_Name"])]
        for uniqueVal in sorted(set(values)):
            self.items.append(uniqueVal)
    def onEnter(self):
        pass
    def refresh(self):
        pass
-Steven
WesMiller
Did you see this post Dynamically Select Feature in Map with Python Addin
EDIT:
Looks like you'll need to add something similar to below
df = arcpy.mapping.ListDataFrames(mxd)[0]
extent = df.extent
extentPoly = arcpy.Polygon(arcpy.Array([arcpy.Point(extent.XMin, extent.YMin), arcpy.Point(extent.XMin, extent.YMax), arcpy.Point(extent.XMax, extent.YMax), arcpy.Point(extent.XMax, extent.YMin)]))
arcpy.SelectLayerByLocation_management(yourlayer, 'intersect', extentPoly )
WesMiller
EDIT:
extent = df.extent
StevenGraf1
So basically I need to do the following:
-Select my layer based on location (which would be the extent of the map)
-Push those field values from the selected into the combobox
-Then select by attributes
-Steven
WesMiller
Sounds right to me. let me know how it turns out. I tested the code in my armap python interpreter and it selects only the features that intersect with data frames extent. You may want to change the data frame [0] to the active data frame.
StevenGraf1
That selects all the features, but it doesn't push the field unique values to the combobox.
Wonder if I need to create a temporary layer from the select by location results to populate the combobox with the unique values.
-Steven
StevenGraf1
Nevermind, It does populate the unique values in the combobox for the select by location query.  It seems to only run once though.  Going to test some more.
-Steven
WesMiller
try using
arcpy.env.overwriteOutput = "true"
StevenGraf1
Guess I should clarify a bit more. The Location search fires every time, but the unique field values only get pushed to the combobox the first time.  I have a button set to clear selection.
Here's my script.  It's a bit different from my original.
import arcpy
import pythonaddins
class LeveeSystemName(object):
    """Implementation for LeveeSearch_addin.LeveeSystemName (ComboBox)"""
    def __init__(self):
        self.items = []
        self.enabled = True
        pass
        global layer
        global df
        layer = arcpy.mapping.ListLayers(self.mxd, "Levee Centerline (Segment Only)")[0]
        df = arcpy.mapping.ListDataFrames(self.mxd, "Region VII") [0]
        extent = df.extent
        arcpy.SelectLayerByLocation_management(layer, 'intersect', extentPoly )
        self.items = []
        values = [row[0] for row in arcpy.da.SearchCursor(layer, ["FC_SYSTEM.System_Name"])]
        arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", "FC_SYSTEM.System_Name = '" + selection + "'")
    def onEnter(self):
        pass
    def refresh(self):
        pass
class ClearSelected(object):
    """Implementation for LeveeSearch_addin.ClearSelected (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        arcpy.SelectLayerByAttribute_management(layer, "CLEAR_SELECTION")
-Steven
WesMiller
Do you have it working now?
Are you planning on repopulating with your clear selected button?
StevenGraf1
I was wanting it to repopulate the combo box after clearing the selection but it's not.  After the entire script runs, the only piece that runs is the selection by location.  The combobox never repopulates so I can select a new value and zoom to.
-Steven
