Limit combobox results to map extent
7708
12
03-07-2016 08:37 AM
StevenGraf1
I'm using this thread as the base for my python addin toolbar.How to populate Add-In Combo Box with attributes
I was wondering if it was possible to limit the field unique values to whats in the map extent. There are thousands of unique values which doesn't take long to populate the combobox but to help the end user I would like to limit those to what's in the map extent.
Here's my python code so far.  You select the specific layer, then it sorts and pushes the unique values to a combobox. Once you select a feature from the drop down, it selects and zooms to that feature.
import arcpy
import pythonaddins
class leveeLayerListSelector(object):
    """Implementation for LeveeSearch_addin.comboboxLayerList (ComboBox)"""
    def __init__(self):
        self.items = []
        self.editable = True
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWWWWWWWWWWWWWWWW'
        self.width = 'WWWWWW'
    def onEditChange(self, text):
        pass
    def onFocus(self, focused):
        if focused:
            self.mxd = arcpy.mapping.MapDocument('current')
            layers = arcpy.mapping.ListLayers(self.mxd)
            self.items = []
            for layer in layers:
                self.items.append(layer.name)
    def onEnter(self):
        pass
    def refresh(self):
        pass
    def onSelChange(self, selection):
        global fc
        fc = arcpy.mapping.ListLayers(self.mxd, selection)[0]
class leveeSystemSelector(object):
    """Implementation for LeveeSearch_addin.comboboxLeveeSystem (ComboBox)"""
    def __init__(self):
        self.items = []
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW'
        df = arcpy.mapping.ListDataFrames(self.mxd, "Layers") [0]
        arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", "System_Name = '" + selection + "'")
        df.zoomToSelectedFeatures()
        arcpy.RefreshActiveView()
        pass
        global layer
        layer = arcpy.mapping.ListLayers(self.mxd, fc)[0]
        self.items = []
        values = [row[0] for row in arcpy.da.SearchCursor(layer, ["System_Name"])]
        for uniqueVal in sorted(set(values)):
            self.items.append(uniqueVal)
    def onEnter(self):
        pass
    def refresh(self):
        pass
-Steven
WesMiller
You may consider changing the onFocus to populateCombobox function and recreate onFocus calling populateCombobox and then you could also call it from your clear selection button.
StevenGraf1
Thanks!  I was in the process of moving the location search to a button and now it seems to be functioning right.  I will test some more and post my code.
-Steven
StevenGraf1
Here's my full code.  This is for use within an esri addin.  The first button allows you to select the features that are within the extent.  The combobox has unique values of a specified field from the features within the extent.  Select a feature to zoom to it.  The 'X' button clears selected results.  The PDF export button isn't functional yet.  The PDF button will be for exporting the selected feature as a PDF map while dynamically adding attributes to the pdf map. I don't know if this is possible yet.  I'll probably be opening another thread for that part.  Thanks for the help this far
-Steven
import arcpy
import pythonaddins
class selectByLocation(object):
    """Implementation for LeveeSearch_addin.ExportPDF (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        df = arcpy.mapping.ListDataFrames(self.mxd, "Region VII") [0]
        layer = arcpy.mapping.ListLayers(self.mxd, "Levee Centerline (Segment Only)")[0]
        extent = df.extent
        extentPoly = arcpy.Polygon(arcpy.Array([arcpy.Point(extent.XMin, extent.YMin), arcpy.Point(extent.XMin, extent.YMax), arcpy.Point(extent.XMax, extent.YMax), arcpy.Point(extent.XMax, extent.YMin)]))
        arcpy.SelectLayerByLocation_management(layer, 'intersect', extentPoly)
class LeveeSystemSelector(object):
    """Implementation for LeveeSearch_addin.LeveeSystemName (ComboBox)"""
    def __init__(self):
        self.items = []
        self.enabled = True
        pass
        global layer
        global df
        self.items = []
        values = [row[0] for row in arcpy.da.SearchCursor(layer, ["FC_SYSTEM.System_Name"])]
        arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", "FC_SYSTEM.System_Name = '" + selection + "'")
    def onEnter(self):
        pass
    def refresh(self):
        pass
class ClearSelection(object):
    """Implementation for LeveeSearch_addin.ClearSelected (Button)"""
    def __init__(self):
        self.enabled = True
    def onClick(self):
        arcpy.SelectLayerByAttribute_management(layer, "CLEAR_SELECTION")
class PDFExport(object):
    """Implementation for LeveeSearch_addin.exportPDF (Button)"""
    def __init__(self):
        self.enabled = True
    def onClick(self):
        pass
