Deploying a Custom Web Map App on Portal
4735
7
03-02-2016 01:22 PM
BrandynFriedly
Hi All,
I'm new to ArcGIS Portal and the JS API, and am looking to start publishing in-house web apps for our organization.  One thing that I'm struggling to find in documentation is how to create and deploy a completely custom web map application on Portal.
It looks to me from the documents that you have to use the Web App Builder and pick widgets/themes, but what if I'd like to just write a map app from scratch?  Is there any reason why you can't just use Leaflet or OpenLayers.js to create a map that is served up by Portal and communicating with your ArcGIS Server?  I guess I don't understand why I'd need ESRI/Leaflet and have Dojo baked into all my apps.
So my two questions are:
  1. Can I just write the code for an app and deploy that to Portal, without using a Web App Builder?
  2. Do I have to use ArcGIS.js?
Any suggestions or reading related to this would be much appreciated!
Brandyn
MichaelLinden
Hi, are you still wondering about this?
AdrianWelsh
MVP Honored Contributor
Michael,
Do you have a good reply for this? It looks like when this thread was created, I must have clicked "I have the same question" since I got a notice when you replied!
MichaelLinden
Hi Adrian,
If i'm interpreting the question correctly, then yes I do. Are you wanting to create your own themes and widgets instead of using the out of the box web app builder widgets/themes?
AdrianWelsh
Yes? I can't remember why I marked I had the same question but I must had needed this somewhere down the line. But yes, I want to [at some point] create my own widgets/themes.
MichaelLinden
Ok, so I started out just like you and knew absolutely nothing about Javascript or app development or anything and now my company uses an app that i coded from scratch with a custom theme and everything. I'm not tooting my own horn I'm just saying that I know exactly where you're coming from and I could be a good resource for you! Plus I'm an Aggie myself (class of '13). So here's where I started:
This is tutorial is a decent resource to getting started with making your own theme:
Create a theme—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
There's a decent ESRI training video that shows you how to create your own controller widget that i'm trying to find for you, but having trouble locating it. I'll keep looking.
I also followed this tutorial to create my first widget and from there began experimenting with it and customizing it.
Create a ListView widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Do you have experience with Javascript and HTML? I bought a couple textbooks and read through them to start learning how to code using those two languages. I bought these books:
https://www.amazon.com/Web-Design-HTML-JavaScript-jQuery/dp/1118907442/ref=sr_1_4?ie=UTF8&qid=152632...
Let me know what you're next questions are! I'm looking forward to helping you out!
AdrianWelsh
Thanks Michael. If I was in the right place for this at the moment, I would be working through this. For now, I just create WAB maps (developer style), with custom widgets, and host them on a web server, not through ArcGIS Enterprise or Portal. When I get those platforms more set up, I will be revisiting this thread. I appreciate your help.
MichaelLinden
Ah ok I may have gotten too excited to help someone out, haha. Good luck!
