configure network to avoid traffic
2694
02-29-2016 01:30 PM
GustavoCordero
I am using arcgis 10.3
I have a network dataset with historical traffic information
I need to resolve a route,
If there is traffic take another route
how and where should I set my network to avoid traffic
example
DanPatterson_Retired
were are you setting the impedances or are you using segment length? (the default)  You could add speed limit, time or other cost fields to your table to design networks under different scenarios (ie rush hour etc).  Effectively, you can turn a major highway into a poor route choice, just like rush hour in reality.  Documentation is given in the network analyst help topis and the tutorial examples, that had been cited as links in your previous posts
GustavoCordero
Hello Friend
  currently I have a table of profiles and historical calles_conpefiles
what I need is that when you make a route based on the hitórico ahorario
  if exite traffic, my route to take another path, I still investigating and have not optenido results
GustavoCordero
I'm using the segment length
