How do I enable the processing window that shows at the bottom of Arcmap when running a spatial analysis
14640
02-28-2016 10:21 AM
CaroleWacta
I used to be able to see through a small tab at the lower right of ArcMap if the analysis was running...
I now have to use the result window which works okay, but I will like to have the running tab back at the bottom...
can someone please tell me whereto enable it?
Thank you in advance,
C
DanPatterson_Retired
do you mean the progress bar as discussed here Using geoprocessing options to control tool execution—Help | ArcGIS for Desktop
check
Background and foreground processing
check
CaroleWacta
yes progress bar...
thank you.
c
JayantaPoddar
There is a topic in ArcGIS Ideas. This seems to have been taken care in ArcGIS Pro.
ArcGIS Idea - geoprocessing progress in background needs better indicator
Think Location
