Update Map Service URL?
3274
02-26-2016 02:30 PM
LauraMiles1
I have a map service ie.
var layerAgreementsOnly = new ArcGISDynamicMapServiceLayer("Census (MapServer) ");
What if I want to change the url? So if I get a security error when loading the map, I would like to switch out the existing url for another one that the user has permission to view. But I'm not sure the syntax or if this is possible.
        layerAgreementsOnly.on("error", function(result){
            var errCode = result.error.code.toString();
            //Test if a 403 security error has been received
            if (errCode.indexOf("403" > -1)){
              // code to update url here?
               console.log("Error " + errCode + ": " + result.error.message);
RobertScheitlin__GISP
Laura,
  Here is my sample for this:
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script src="http://js.arcgis.com/3.10/"></script>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/_base/lang",
      "esri/request",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dojo/domReady!"
    ], function(
      Map, lang, esriRequest
      map = new Map("map", {
        basemap: "topo",
        center: [-120.1883, 37.0868],
        zoom: 6
      esriRequest({
          url:"http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M...",
          content:{
            f:'json'
          handleAs:'json',
          callbackParamName:'callback',
          timeout:15000
        }).then(lang.hitch(this,function(response){
          alert("Data was retrieved");
        }),lang.hitch(this,function(error){
          alert("Data failed");
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:100%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
Laura,
   The way I would handle this is to use an esriRequest with the url like "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M... " to see if you have the permissions to access the layer and if not then add the layer to the map using the other url. This way you are not actually adding anything to the map until you know you have the correct permissions.
LauraMiles1
Thanks Robert, I think this is just what I was looking for. I have it set up like this
         var secRealEstate = esriRequest({
            url: "myURL",
            timeout: 100 //Set this in milliseconds
        secRealEstate.then(requestSucceeded, requestFailed);
        function requestSucceeded(){
        function requestFailed(){
            alert("Data was NOT retrieved");
But even when using the non-secured url, it always comes back with requestFailed. Do you see anything I've done incorrectly? (If I don't set a timeout, it seems my map never reaches the "update-end" event).
Laura,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/_base/lang",
      "esri/request",
      "dojo/domReady!"
    ], function(
        basemap: "topo",
        zoom: 6
      esriRequest({
          content:{
            f:'json'
          handleAs:'json',
          timeout:15000
  </script>
</head>
  </div>
</body>
</html>
LauraMiles1
This works - thanks Robert!
