how to get corresponding table rows from selectionset?
2259
02-25-2016 06:48 PM
SanjayGiri
I am an amateur in arcgis development so i have come here for some light into the issue i am facing. First of all i have a layer called GridSheet whose attribute table is as shown below:
The corresponding map looks like the following:
I was able to select all the surrounding grids by the following code. Now, i want to get the corresponding table rows of the selected grid boxes. From the rows i want to extract the MapSheetNumber of the selected boxes or sheets.  How can i do that?
    '*** Selects the center grid box or cell
            SelectFeatureInMap(pGridFeatureLayer, pQFilter)
  '*** Then the following code will select all boxes that touch the above center box
            Dim pFeatureLayer As IFeatureLayer
            pFeatureLayer = pGridFeatureLayer
            Dim pLayer As IFeatureSelection
            Dim pSelection As ISelectionSet
            Dim pCursor As IFeatureCursor
            pLayer = pFeatureLayer
            pSelection = pLayer.SelectionSet
            Dim pEnumIds As IEnumIDs
            pEnumIds = pSelection.IDs
            pSelection.Search(Nothing, True, pCursor)
            pFeature = pCursor.NextFeature
            If pFeature Is Nothing Then
                Exit Sub
            End If
            Dim geometryBag As IGeometryBag = New GeometryBagClass()
            Dim geometryCollection As IGeometryCollection = CType(geometryBag, IGeometryCollection)
            Dim geoDataset As IGeoDataset = CType(pFeatureLayer.FeatureClass, IGeoDataset)
            Dim spatialReference As ISpatialReference = geoDataset.SpatialReference
            geometryBag.SpatialReference = spatialReference
            While Not pFeature Is Nothing 'Add all the polygons selected to the geometry bag
                geometryCollection.AddGeometry(pFeature.Shape)
            End While
            Dim pSpatialFilter As ISpatialFilter
            pSpatialFilter = New SpatialFilterClass
            pSpatialFilter.Geometry = geometryBag
            pSpatialFilter.GeometryField = pFeatureLayer.FeatureClass.ShapeFieldName
            pSpatialFilter.SubFields = "Shape"
            pSpatialFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelTouches
            pFL = pLayer
            pFClass = pFL.FeatureClass
            pSelection = pFClass.Select(pSpatialFilter, esriSelectionType.esriSelectionTypeHybrid, esriSelectionOption.esriSelectionOptionNormal, Nothing)
            Dim noCount As Short
            pSelection.Add(pEnumIds.Next)
            noCount = pSelection.Count
            pLayer.SelectFeatures(pSpatialFilter, esriSelectionResultEnum.esriSelectionResultNew, False)
            pMxDoc.ActiveView.Refresh()
I appreciate your help if you can point to me in the right direction. Thanks a lot!!
