Batch Processing in Model Builder - Delete rows then Append
11770
14
02-25-2016 03:21 PM
SanhitaChatterjee1
I am trying to delete rows from multiple feature classes with prefix TCEMaster_* (such as TCEMaster_Centerline, TCEMaster_Fence etc.) in TCEMaster.SDE ----then append the feature classes with data from another sde. Names of the feature classes in Input dataset is without the prefix (such as Centerline, Fence etc.).
My ultimate goal is to run a script/batch file routinely.
Should I use modelbuilder with Iterator and then export to python or a script in python. I am not much of an expert in python. See attached what I got started in modelbuilder.  I  have also attached a screenshot of the databases exported to FGDB  for testing purposes. Target dataset is TCEMaster in test_TCE.gdb and input dataset is R0007199 in test.gdb.
Any help will be highly appreciated.
MichaelVolz
Esteemed Contributor
Start with model builder for 1 feature class and then export out to python.  Python has some great tools for iterating.
SanhitaChatterjee1
Can you please tell me what parameter is missing here in the python iterator?
Input dataset is Temp_test.gdb\\R0007199
Target dataset is test_TCE.gdb\TCEMaster
Target dataset has a wildcard TCEMaster_*
Both datasets have same schema- only difference is the wildcard in target dataset.
# Import arcpy module
import arcpy
arcpy.env.workspace = "C:\Users\sc\Desktop\test\test_TCE.gdb\TCEMaster"
fcs = arcpy.ListFeatureClasses("TCEMaster_*")
Inputdataset = "C:\\Users\\sc\\Desktop\\test\\Temp_test.gdb\\R0007199"
Targetdataset = "C:\Users\sc\Desktop\test\test_TCE.gdb\TCEMaster"
# Process: Append
for fc in Inputdataset:
    arcpy.Append_management(fc, fcs, "TEST", "", "")
MichaelVolz
Do you want to process all feature classes in a file geodatabase?
Or are you trying to process all feature classes in a specific feature dataset in a file geodatabase?
SanhitaChatterjee1
Specific feature dataset "TCEMaster" and all FCs in this feature dataset
MichaelVolz
# Process: Append
Instead of for fc in Inputdataset:
for fc in arcpy.ListFeatureClasses('*','All',Inputdataset):
SanhitaChatterjee1
Thanks Michael.
It works if I do not have a wildcard set (such as without "TCEMaster_*" in target dataset). When I have the wildcard defined I get an error:
File "C:/Users/sc/Desktop/test/Append_Iterator_Export_Test.py", line 25, in <module>
TypeError: 'NoneType' object is not iterable
This is what I have now:
import arcpy
# Process: Append
MichaelVolz
Are you trying to access multiple feature datasets in your code and then all feature classes in all the feature datasets?
Or do you just want to iterate all feature classes in one feature dataset?
SanhitaChatterjee1
Michael, It is all feature classes in one dataset.
MichaelVolz
Then if the code without the wildcard runs without error, that should do the trick for you.  Now if you want to automate this, just add the python script to Windows Task Scheduler.
