I'm trying to generate a token to access
http://landscape1.arcgis.com/arcgis/rest/services/USA_Geology_Units/MapServer
var params = {
username: username
password: password
//referer: 'http://l' + $(location).attr("host") + '/',
referer: 'http://landscape1.arcgis.com/arcgis/rest',
expiration: 1440,
f: "json"
$.ajax({
url: "https://www.arcgis.com/sharing/rest/generateToken?",
type: "POST",
dataType: "json",
data: params,
success: function (data) {
the token in the data object is not working, the landscape1 just redirects to the login page.
Any ideas?
Here my function for that. I hope this helps.
function validate() { var username = 'YOUR USERNAME'; var password = 'YOUR PASS'; var http = new XMLHttpRequest(); var url = "YOUR TOKEN URL"; var str1 = "username="; var str2 = "&password="; var str3 = "&f=json&client=requestip&expiration=1440"; var params = str1.concat(username, str2, password, str3); //f="json", client="requestip", expiration="1440" http.open("POST", url, true); http.setRequestHeader("Content-type", "application/x-www-form-urlencoded"); http.setRequestHeader("Content-length", params.length); http.setRequestHeader("Connection", "close"); http.onreadystatechange = function () { if (http.readyState == 4 && http.status == 200) { var tokenResponse = http.responseText; token=JSON.parse(tokenResponse); if (tokenResponse.search("error") == -1) { esri.id.registerToken( {server: 'YOUR REST SERVICE', userId: 'YOUR EXAMPLE USER', token: token.token, expires: token.expires, ssl: false }); //DO SOMETHING ..... } else { alert("Incorrect Login, try again."); } } }; http.send(params); return false; }
