Problem with ArcGIS JavaScript API: labelling a feature layer
4486
6
02-22-2016 07:57 PM
RichardMacNeill1
Below is script intended to label the axes of a grid. But first, I need to have the label displayed. The labels are not displaying. Can anyone out there suggest what I may be doing wrong?
(My apologies for the repeated requests for help. I'm learning as I go and, until I take a JavaScript course, it will be 2 steps forward and one back).
The script takes a set of coordinates in the URL and displays a box. It then displays a feature layer grid with fields containing latitude and longitude values for each grid line. To overcome one problem at a time, I have replaced the field name in the json expression with a constant text value.
<!DOCTYPE html>
<html>
  <head>
   <title>Bounding Box</title>
   <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7">
   <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
<style>
  html, body, #mapDiv{padding: 0;margin: 0;height: 100%;}
</style>
<script src="https://js.arcgis.com/3.15/"></script>
<script type="text/javascript" src="dojo/dojo.js"
    data-dojo-config="parseOnLoad: true"></script>
<script>
var URLExtent = this.location.href.split("=")[1].split("&")[0].split(",");
require(["esri/map","esri/layers/FeatureLayer","esri/geometry/extent","esri/SpatialReference","esri/geometry/Polygon","esri/graphic","esri/symbols/SimpleFillSymbol"
,"esri/symbols/SimpleLineSymbol","esri/Color","esri/layers/GraphicsLayer","esri/dijit/Scalebar",
"esri/layers/LabelLayer",
"esri/symbols/TextSymbol",
"esri/symbols/Font",
"esri/layers/LabelClass",
"dojo/parser","dojo/on","dojo/domReady!"],
function(Map,FeatureLayer,extent,SpatialReference,Polygon,Graphic,SimpleFillSymbol,SimpleLineSymbol,Color,
LabelLayer,
TextSymbol,
Font,
LabelClass,
parser,Scalebar,on) {
var arrayOfCoordinates = [[URLExtent[0],URLExtent[1]],[URLExtent[2],URLExtent[1]],[URLExtent[2],URLExtent[3]],[URLExtent[0],URLExtent[3]],[URLExtent[0],URLExtent[1]]];
var spatialRef = new esri.SpatialReference({wkid:4326});
var startExtent = new esri.geometry.Extent(URLExtent[0],URLExtent[1],URLExtent[2],URLExtent[3]);
startExtent.spatialReference = spatialRef;
    map = new Map("mapDiv", {
      basemap: "streets",
   extent: startExtent,
   showLabels : true
var box = new esri.geometry.Polygon(arrayOfCoordinates);
var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
   new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,
   new Color([255,0,0]), 2),new Color([255,255,255,0.25])
var lsymbol = new TextSymbol(new Color([255,0,0]),new Font("14pt",Font.STYLE_ITALIC,Font.VARIANT_NORMAL, Font.WEIGHT_BOLD,"Arial"));
var json = {
"labelExpressionInfo": {"value": "longitude"}
var lc = new LabelClass(json);
lc.symbol = lsymbol;
var featureLayer = new FeatureLayer("http://services2.arcgis.com/rzk7fNEt0xoEp3cX/arcgis/rest/services/graticule_GDA94/FeatureServer/0",{
  //labelingInfo: [lc],
  showLabels: true,
  outFields: ["*"]
map.on("load",function(){
  var graphic = new Graphic(box,sfs);
  map.graphics.add(graphic);
  map.setZoom(map.getZoom()-1);
  featureLayer.setLabelingInfo([lc]);
  map.addLayer(featureLayer);
</script>
  </head>
<body class="claro">
  <div id="mapDiv"></div>
</body>
</html>
TyroneBiggums
This line of code:
... is expecting an '=' in your URL. For starters, just to be sure, does your URL have values with an '=' in it?
Try F12 developer tools and see if any errors/warnings pop up in the console.
RichardMacNeill1
Thanks Tyrone
My apologies for not supplying more info on the context. The call has the structure: http:<server reference and javascript>?extent=<minx, miny,maxx,maxy>&mapOnly=true. This part seems to work. I've received valuable advice on programming basics, but am also beginning to think that Internet Explorer may also be causing some problems. Using Chrome gives variant results.
RobertScheitlin__GISP
Richard,
   Some things you need to get out of the habit of and into the habit of right away:
Do not use esri.geometry.Polygon. This is what is considered legacy style coding.
Do use the AMD style coding of the objects by adding the require for "esri/geometry/Polygon".
You had "esri/geometry/extent" in your requires and that returns a error as the is no extent.js in the esri geometry library. Extent (notice upper case of E).
You were missing some vars for the requires you had.
Notice in my code line 25 of my requires have the same number of objects as line 32 of my subsequent vars for those requires. This helps me to be sure that my vars match my requires.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script>
    require([
        "esri/map", "esri/layers/FeatureLayer", "esri/geometry/Extent", "esri/SpatialReference",
        "esri/geometry/Polygon", "esri/graphic", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/Color", "esri/layers/GraphicsLayer", "esri/dijit/Scalebar", "esri/layers/LabelLayer",
        "esri/symbols/TextSymbol", "esri/symbols/Font", "esri/layers/LabelClass", "dojo/parser", "dojo/on",
        "dojo/domReady!"
      function (
        Map, FeatureLayer, Extent, SpatialReference,
        Polygon, Graphic, SimpleFillSymbol, SimpleLineSymbol,
        Color, GraphicsLayer, Scalebar, LabelLayer,
        TextSymbol, Font, LabelClass, parser, on
          [URLExtent[0], URLExtent[1]],
          [URLExtent[2], URLExtent[1]],
          [URLExtent[2], URLExtent[3]],
          [URLExtent[0], URLExtent[3]],
        var spatialRef = new SpatialReference({
          wkid: 4326
        var startExtent = new Extent(URLExtent[0], URLExtent[1], URLExtent[2], URLExtent[3]);
          basemap: "streets",
          showLabels: true
        var box = new Polygon(arrayOfCoordinates);
            new Color([255, 0, 0]), 2), new Color([255, 255, 255, 0.25])
        var lsymbol = new TextSymbol(new Color([255, 0, 0]), new Font("14pt", Font.STYLE_ITALIC, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "Arial"));
        var json = {
        var featureLayer = new FeatureLayer("http://services2.arcgis.com/rzk7fNEt0xoEp3cX/arcgis/rest/services/graticule_GDA94/FeatureServer/0", {
          showLabels: true,
          outFields: ["*"]
        map.on("load", function () {
          var graphic = new Graphic(box, sfs);
          map.setZoom(map.getZoom() - 1);
  </script>
</head>
</body>
</html>
RichardMacNeill1
Thanks Robert (again). Valuable advice I'll endeavour to follow.
I'm finding that the behaviour of my script in Internet Explorer differs from Chrome. Are there specific requirements for each and, if so, is there a way of ensuring a capability for both?
Richard,
   Which version of IE are you targeting? Because you have this meta tag in your code:
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7"> Which is the issue.
Normally you would want to use:
<meta http-equiv="X-UA-Compatible" content="IE=Edge" />
RichardMacNeill1
Unofficial
Robert
I'm using IE10. I'll use your suggested code and am about to see how best to make use of its Developers tool.
Richard
