convert VB expression to python
11964
33
02-23-2016 07:32 AM
by Anonymous User
Not applicable
I am new to python.  I am using a model to automate a data update process.  Part of the model is to calculate a new field by concatenating 3 other fields and left trimming to remove white space as needed.  Below is the VB expression.  When I use python to automatically run this model it fails at the expression to calculate the field.   Below is the VB expression.  I cannot find an example of how this would look as a python expression.  Can anyone help?
FullStreet =
LTrim( [LOCN] &" " &  LTrim( [LOCD] & " " &  [LOCS]))
Any help would be greatly appreciated.
Sincerely,
Nita L Hester
KenBuja
MVP Esteemed Contributor
Please note GeoNet Help​ help space is for questions about GeoNet itself, not about specific programming questions. I'm moving it to the Python​ space. Also, using tags when asking questions will make it easier to be searched on.
AdrianWelsh
MVP Honored Contributor
Could you try .lstrip()?
So !LOCN!.lstrip() + " " + !LOCD!.lstrip() + " " + !LOCS!.lstrip()
Would that work?
by Anonymous User
Not applicable
Thanks, I tried this and it works, but I need to remove the white spaces if there is no LOCN and or LOCD data.
FreddieGibson
Honored Contributor
You'll want to look at the python help for concatenating strings. The simplest option would be as follows.
A cleaner example would be to use string.format
"{0} {1} {2}".format(!LOCN!.lstrip(), !LOCD!.lstrip(), !LOCS!.lstrip())
String Concatenation and Formatting
Python String lstrip() Method
by Anonymous User
Not applicable
Thanks, I tried this and it works, but I need to remove the white spaces if there is no LOCN and or LOCD data.  How do I remove white space from after adding it between the fields if there is no associated data for both or either of the 1st 2 fields?
AdrianWelsh
You will have to use the code block to make a basic logic statement utilizing If..Then.
See this article on the basics for doing this:
Calculate Field examples—Help | ArcGIS for Desktop
and scroll down to "Using code blocks"
I am guessing that you will need to check each field if it is empty or now. I would start it like:
If !LOCN!.len() <> 0
(but you'll have to tinker around with the code to make it behave properly!)
JamesCrandall
Like Adrian mentions, you will need to add some Pre-Logic code to the expression.  From the field calculator:
1. Right click the field to calculate and in the Field calculator dialog, choose the appropriate Parser (ie, Python)
2. Place a check in the "Show Codeblock" box
3. In the Pre-Logic Script Code: section, add a def() that should look something like (I'm not totally certain about the exact logic desired, but this will get close I think):
def processInput(input1, input2, input3):
  if input1 == "" or input2 == "":
     return input3
  else
     return input1.strip() + "" + input2.strip() + "" + input3.strip()
4. In the box below the Pre-Logic script area, enter in the def() name and add your field parameters:
processInput( !LOCN!, !LOCD!, !LOCS!)
Order them appropriately.
edit: apologies as I'm showing strictly from the Field Calculator dialog, which does not specifically address the original question of a field calculation from within a model or python script.  You will have to adapt this as needed.
RebeccaStrauch__GISP
And to follow James' code, if you want to then call this within a python script..
     return input3
  else
     return input1.strip() + "" + input2.strip() + "" + input3.strip()  """
# I'm showing passing three fields, but can be other input that needs to be passed
arcpy.CalculateField_management("inFC", "fieldToCal", "processInput( !field1!, !field2!, !field3!)", "PYTHON_9.3", myCode_block)
AdrianWelsh
Thanks Rebecca!
[/bookmarking this for later...]
