FeatureLayer & MapImageLayer - Bootstrap checkboxes buttons to toggle layers
2671
02-13-2016 02:38 PM
MateuszCzechowicz
Hello everyone!
I'm a total beginner in web maps and I don't know how to create bootstrap checkboxes buttons to toggle my FeatureLayer and MapImageLayer
I found an example: Edit fiddle - JSFiddle​ . This works, but with ArcGISDynamicMapServiceLayer.
Could anyone help me?
My layers:
            map.on("load", function() {
            var mil = new esri.layers.MapImageLayer(
                'opacity': 0.3
            map.addLayer(mil);
            var mi = new esri.layers.MapImage({
              'extent': { 'xmin': 24.8312980522177, 'ymin': 60.1396272514532, 'xmax': 25.2344061856669, 'ymax': 60.2895551888062},
              'href': 'https://aalto.maps.arcgis.com/sharing/rest/content/items/28b2611073c4482aabf85fec5c75454f/data'
            mil.addImage(mi);
            var viewpoints = new FeatureLayer("https://services3.arcgis.com/DrStYMBZkn3kRBe9/arcgis/rest/services/view_points/FeatureServer/0", {outFields: ["*"]});
            map.addLayer(viewpoints);
RobertScheitlin__GISP
Mateusz,
  Here is that code modified to use a FeatureLayer and a MapImageLayer:
<!DOCTYPE html>
<html>
<head>
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
  <title>Explicitly Create Map Service Layer List</title>
  <link rel="stylesheet" href="http://ajax.googleapis.com/ajax/libs/jqueryui/1.11.1/themes/smoothness/jquery-ui.css" />
  <link rel="stylesheet" href="http://maxcdn.bootstrapcdn.com/bootstrap/3.2.0/css/bootstrap.min.css">
  <link rel="stylesheet" href="http://maxcdn.bootstrapcdn.com/bootstrap/3.2.0/css/bootstrap-theme.min.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css">
  <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.11.1/jquery.min.js"></script>
  <script src="http://maxcdn.bootstrapcdn.com/bootstrap/3.2.0/js/bootstrap.min.js"></script>
  <script src="http://js.arcgis.com/3.15/"></script>
  <script>
    var map;
    require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "dojo/dom",
        "dojo/on",
        "dojo/query",
        "esri/layers/MapImage",
        "esri/layers/MapImageLayer",
        "dojo/domReady!"
      function (Map, FeatureLayer, dom, on, query, MapImage, MapImageLayer) {
        var featureLayer;
        map = new Map("map",{
          basemap: "streets",
          center: [-122.53569449217555, 47.8017140515922],
          zoom: 7
        var radarMi = new MapImage({
          'extent': { 'xmin': -125.725156, 'ymin': 45.222770, 'xmax': -119.252062, 'ymax': 51.156440, 'spatialReference': { 'wkid': 4326 }},
          'href': "http://radar.weather.gov/ridge/RadarImg/N0R/ATX_N0R_0.gif"
        radarMi.height = 550;
        radarMi.width = 600;
        radarMi.scale = 1;
        var nwsRadarLayer = new MapImageLayer();
        nwsRadarLayer.addImage(radarMi);
        map.addLayer(nwsRadarLayer);
        featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2");
        map.addLayer(featureLayer);
        $('.btn-primary input[type="checkbox"]').prop('checked', true);
        var checkBoxes = query(".btn-primary");
        for (var j = 0; j < checkBoxes.length; j++) {
          on(checkBoxes, "click", updateLayerVisibility);
        function updateLayerVisibility() {
          setTimeout(function () {
            var inputs = query(".list_item");
            var inputCount = inputs.length;
            for (var i = 0; i < inputCount; i++) {
              if(i === 0) nwsRadarLayer.setVisibility(inputs.checked);
              if(i === 1) featureLayer.setVisibility(inputs.checked);
          }, 10);
  </script>
</head>
<body>
  <br />
  <br /> Layer List :
  <span id="layer_list">
    <div class="btn-group" data-toggle="buttons">
      <label class="btn btn-primary active">
        <input type="checkbox" class="list_item" id="layer0CheckBox"> Radar
      </label>
        <input type="checkbox" class="list_item" id="layer1CheckBox"> Counties
      </label>
    </div>
  </span>
  <br />
  <br />
  <div id="map" class="claro" style="width:600px; height:400px; border:1px solid #000;"></div>
</body>
</html>
Mateusz,
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
  <script>
    var map;
    require([
        "esri/map",
        "dojo/dom",
        "dojo/on",
        "dojo/query",
        "dojo/domReady!"
        var featureLayer;
          basemap: "streets",
          zoom: 7
        radarMi.scale = 1;
          }, 10);
  </script>
</head>
<body>
  <br />
  <br /> Layer List :
      </label>
      </label>
    </div>
  </span>
  <br />
  <br />
</body>
</html>
MateuszCzechowicz
Thank you very much Robert. That works!
