Find Widget
2440
02-12-2016 09:59 AM
DavidForbuss1
Does anyone know if it's possible to use the "Find" widget that's included in the "Find" webapp template in other web apps?  I really like how it begins searching whichever feature class you point it to immediately as opposed to the geocoder widget which requires you to hit the search button.
This is what I'd like to use, but it's not listed as an available widget in the webappbuilder:
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi David,
Take a look at the Search widget in Web AppBuilder.  You can configure it to search a specific layer in your web application.
DavidForbuss1
Thanks Jake,
I tried that and it works just ok.  I get different results than if I use the find widget on the same feature layer.  I was just hoping there was some way to add it, or make it available to be added in the webapp builder.
