how do i buffer a point on button click
4401
02-08-2016 01:34 AM
ADITIROY
Hi everyone,
I need to buffer a point on button click instead of map click in ArcGIS JavaScript api. How do I  make the make the point buffer on button click?
Aditi
JakeSkinner
Esri Esteemed Contributor
Hi Aditi,
Below is an example on how you can buffer a feature using a button:
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Sample Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
      #button{
        position: absolute;
        top: 50px;
        left: 100px;
        z-index: 5;
    </style>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      var map, graphic;
      require([
        "esri/map", "esri/layers/FeatureLayer", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleFillSymbol", "esri/geometry/Point",
        "esri/graphic", "dojo/_base/Color", "esri/symbols/SimpleLineSymbol", "esri/tasks/GeometryService",
        "esri/tasks/BufferParameters", "esri/SpatialReference",
        "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/parser", "dojo/domReady!"
      ], function(
        Map, FeatureLayer, SimpleMarkerSymbol, SimpleFillSymbol, Point,
        Graphic, Color, SimpleLineSymbol, GeometryService,
        BufferParameters, SpatialReference,
        dom, on, array, parser
        parser.parse();
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-81.792107, 26.150807],
          zoom: 8
        gs = new GeometryService("http://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0",{
            mode: FeatureLayer.MODE_ONDEMAND,
            outFields: ["*"]
        var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
        on(featureLayer, "click", function(evt){
            map.graphics.clear();
            xloc = evt.graphic.geometry.x;
            yloc = evt.graphic.geometry.y;
            var pt = new Point(xloc,yloc,map.spatialReference)
            graphic = new Graphic(pt, symbol);
            map.graphics.add(graphic);
        map.addLayer(featureLayer);
        on(dom.byId("buffer"), 'click', function(evt){
            var params = new BufferParameters();
            params.distances = [10];
            params.bufferSpatialReference = map.spatialReference;
            params.outSpatialReference = map.spatialReference;
            params.unit = GeometryService.UNIT_STATUTE_MILE
            console.log(graphic);
            params.geometries = [graphic.geometry];
            console.log(params);
            gs.buffer(params, showBuffer);
        function showBuffer(bufferedGeometries) {
            console.log(bufferedGeometries);
            var symbol = new SimpleFillSymbol("none", new SimpleLineSymbol("dashdot", new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]));
            array.forEach(bufferedGeometries, function (geometry) {
                graphic = new Graphic(geometry, symbol);
    </script>
  </head>
  <body class='claro'>
    <div id="mapDiv">
        <div id="button">
            <button data-dojo-type="dijit/form/Button" id='buffer'>Buffer</button>
        </div>
    </div>
  </body>
</html>
