Discrepancy Between the Operation Dashboard Map Configuration Settings
2981
02-08-2016 01:47 PM
OLANIYANOLAKUNLE
Please find attached, the difference between the Operations Dashboard map configuration settings page I saw on your recorded seminar and the one I have on my machine. I noticed that there's no dynamic & static radio buttons on mine under the settings pane, what does this mean because I can't add a layer that has real time feeds from my webmap? Thank you
Tags (1)
ChristopherOlsen
It could be that you have not enabled the refresh interval on your web map.  Can you check the web map and see if that layer has a refresh interval set?
OLANIYANOLAKUNLE
Thanks Christopher its now showing as the attached figure 1 and not like the 1 we saw on the recorded training seminar. ThanksMap Configuration Settings Page_II.jpg
