How to delete line ?
2359
11-23-2010 10:21 PM
zeeshanbhatti
i am drawing line using this code reference from
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm
var myLine ={geometry:{"paths":[[[-91.40625,6.328125],[6.328125,19.3359375]]],
  "spatialReference":{"wkid":4326}},
  "symbol":{"color":[0,0,0,255],"width":1,"type":"esriSLS","style":"esriSLSSolid"}};
var gra= new esri.Graphic(myLine);
map.graphics.add(gra);
How can i delete the line if i am trying to draw in above mention way.
The samples for deleting graphics method is not clear if we are drawing using inputs parameters. Can some one help us through code.
timgogl
i dont know of a delete function for objects in javascript, but you might try:
gra.hide(); // hide the graphic
gra=null;
setting it to null 'should' let the js engine know that the object is available for garbage collection, whether it gets collected or not.. who knows.
timgogl
well, this is why i like to read through the forums here, i get to learn new things....
looking at this post: http://forums.arcgis.com/threads/17871-Trouble-with-routing?p=57167&posted=1#post57167
i noticed this user using a remove() method on a graphics object.... so that maybe what you need to use.
heh. ah.. just found the documentation, its under GraphicsLayer, not graphics.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jsapi_start.htm
JohnFreels
You could use the Map.Graphics layer for drawing.  That's what I do.  Call 'map.graphics.clear()' to get rid of them to clear the interface or for redrawing.
Could this solution work for you?
zeeshanbhatti
Well i have solved it .I have declared a global array and pushed all the graphic retreived from database along with unique ID. Then i have removed the desired graphic by using Map.Graphic.Remove(graphic_Line[Id]). Method. And it works for me.
Thanks to All
Regards,
Zeeshan
