Building Raster Mosaic Overview Error appear
3803
02-01-2016 11:27 PM
ShahidHussain
      I tried to create Raster Mosaic Overview I got this message during geoprocessing
"Distributing Mosaic data set operation across 2 parallel instances on the specified host "
some images are partially invisible. how can I fix this error thanks
JayantaPoddar
This is not an error. One geoprocessing operation can use multiple parallel instances depending on the capability of the machine. You could manage it using Geoprocessing > Environments > Parallel Processing.
What version of ArcMap are you using?
You could check this link
arcgis desktop - Missing overviews for mosaic dataset? - Geographic Information Systems Stack Exchan...
Think Location
ShahidHussain
I am using ArcMap 10.3, The building overview shows the gape as you can see with the attached image in last message. why some area is missing?
