Drag and drop not working for batch processing
2405
01-29-2016 10:50 AM
Jon_PaulPierre
I often use batch processing. I recently have an issue with Mr.Sid files not being able to drag and drop into a batch processing operation.
I am trying to do a batch process of unsupervised classification.
I have done this successfully many times in the past.
My issue is that drag and drop will not allow me to place files in the input raster column.
I have a work around where i put the files in the output raster column first and copy to excel and move to input column then paste back into batch processing. This works, however, it's a hassle because I do this operation frequently.
Input raster band and number of bands columns are green. Not sure if they were green in the past.
Anyone have any ideas why this has changed?
I've not updated ArcGIS versions for a while.
I am using 10.2.2.
Thanks in advance for any help.
ChrisSmith7
Honored Contributor
I don't have an answer to your question, but a suggestion to get more views - did you mean to post this in the JavaScript API forum?
Jon_PaulPierre
No, sorry about that.
Thanks for letting me know.
I re-posted. I think I've got it right now.
Thanks much.
RebeccaStrauch__GISP
drag and drop not working for batch processing  Is the repost.
Jon Paul, for future reference, you can use Moving Content​  instead of reposting.  And to share or post in several locations, you can tag other places/spaces/people using @ and the name.
