Creating shp files
3627
01-25-2016 01:17 PM
CurtisShmigelsky1
Hello again :0  I am trying to create a shp file with custom fields for the BC ePASS submission system. This epass system required another set of shp files called Ancillary and Other Applications (_aoa)
In ArcGis Pro, it is possible to modify the shp file to added additional properties/values? The original shp files would be imported into ArcGIS Pro as it would have the area of the disposal.
Thanks for the help again
DanPatterson_Retired
Of course you can add/delete and modify fields and their data.  the online help for ArcMap and ArcGIS Pro have parallels and you can check for comparable functionality between them.  For instance, the add field help is show as follows and you will be able to see that you can switch between desired software when doing queries.  have a look and see what you need in either or both platforms.
Add Field—Data Management toolbox | ArcGIS for Desktop
CurtisShmigelsky1
Thanks again for answering my question
XanderBakker
Esri Esteemed Contributor
Hi Curtis Shmigelsky , could you mark the answer by Dan as the correct answer? See Mark a reply as the Correct Answer
