layer.Graphics not there
2518
01-08-2016 09:57 AM
ScottRowles
I have a WinForms application in VS 2013.  I have referenced the arcgisruntime and can create a graphics layer in the mapcontrol, but the GraphicsLayer that I am creating isn't showing a binding for the Graphics property of the layer for me to add Points, Lines and Polygons.
using System;
using System.Collections.Generic;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Esri.ArcGISRuntime.Controls;
using Esri.ArcGISRuntime.Layers;
using Esri.ArcGISRuntime.Symbology;
using Esri.ArcGISRuntime.Geometry;
using HB.Core.Inventory;
using HB.Core.Tasking;
-----other methods here
        private Boolean DrawLocations()
            try
                //Draw All Locations
                Layer layer = new Esri.ArcGISRuntime.Layers.GraphicsLayer();
                layer.ID = "Locations";
                layer.DisplayName = "Locations";
                mapControl.Map.Layers.Add(layer);
                foreach (Location location in Data.GetLocations())
                    Esri.ArcGISRuntime.Geometry.MapPoint point = new MapPoint(location.Point.X, location.Point.Y, location.Point.Z);
                    Esri.ArcGISRuntime.Symbology.SimpleMarkerSymbol symbol = new SimpleMarkerSymbol();
                    Esri.ArcGISRuntime.Layers.Graphic graphic = new Graphic(point, symbol);
                    layer.Graphics.Add(graphic);
                return true;
            catch (Exception ex)
                throw new Exception("Unable to Draw Locations.", ex);
Any help would be appreciated!
scott
GrigoriyGorodisskiy
Try set  SpatialReference for points.
Esri.ArcGISRuntime.Geometry.MapPoint point = new MapPoint(location.Point.X, location.Point.Y, location.Point.Z, SpatialReferences.Wgs84)
AnttiKajanus1
Could you make sure that your graphics are in the same SpatialReference with MapView.
