ArcGISRuntimeSamplesDesktopViewer not showing basemaps
12144
21
12-22-2015 12:32 PM
SeanNakasone
Hi, I'm having trouble getting the basemaps to display in the github sample (arcgis-runtime-samples-dotnet).  I'm clicking on Mapping > Switch Basemaps > Streets.  It does not show anything in the map.
I installed the Runtime SDK.
I've downloaded the sample-data folder.
Using Visual Studio 2013.
I'm guessing it should show...
"http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
Which I can access from a browser.
Any suggestions?
SeanNakasone1
MatthewBaber
Hi Sean,
Trying following this tutorial visual studio: Use ArcGIS basemaps—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
Happy coding!
SeanNakasone
Thanks for the link Matthew, will do.
SeanNakasone
I don't have .net framework 4.5 which is a requirement, will install then try again.
MatthewBaber
Alright, reach out if it continues to be an issue.
SeanNakasone
oops, looks like I already had 4.5.2.  I guess I'm still having the issue.
MatthewBaber
Does it pull in the other data from the tutorial? Are you only missing the basemap?
SeanNakasone
I tried the tutorial from your link, It's missing both basemap and hurricane layer.
MatthewBaber
Ok, I might be wrong but it sounds like its your firewall or another network issue if no data is passing through when called. If your organization is an ESRI customer try logging a support ticket and they can run diagnostics from there.
SeanNakasone
I tried a tiled cache from our local server, I can see the grid lines on the map, but no image.
