Switching dynamically between infoWindow / Popup in the Map definition
3645
01-08-2016 09:54 AM
TracySchloss
Honored Contributor
I'm working through the example Info window with chart | ArcGIS API for JavaScript The key seems to be the use an infoWindow rather than a popup for the template in the constructor of the Map.
I have other layers in my map, though, where I'd prefer to use popups.  In the map documentation, it looks like I can use map.attr to change this.  map.attr('infoWindow','popup').
Has anyone else encountered this situation and do you have a recommendation or example on how to handle this?  I think I'll need a listener on the selection of the featureLayer that needs the infoWindow rather than popup.  But then I'll need to switch it back to popup for my other layers.
GirishYadav
Hi Tracy,
The InfoWindow and Popup are essentially same things. Popup is an implementation of InfoWindow that has few more features. Both are just a container therefore in most cases just changing the content (InfoWindow/Popup.setContent()) is enough. But if you have a custom popup/InfoWindow that you want to switch. Then use
Map.setInfoWindow(customInfoWindow)
This method is not mentioned in the API documentation but its there.
here is a small example: This attaches an event handler on map click and check whether its clicked on any feature or not. If its not on any feature it changes the info window and its contents. you can insert any logic here. Or if you want the same thing can be done on Layer's OnClick also.
<!DOCTYPE html>
<html>
  <head>
    <title>Popup</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
    <style>
      html, body, #map {
        padding: 0;
        margin: 0;
        height: 100%;
      /* Change color of icons to match bar chart and selection symbol */
      .esriPopup.dark div.titleButton,
      .esriPopup.dark div.titlePane .title,
      .esriPopup.dark div.actionsPane .action {
        color: #A4CE67;
      /* Additional customizations */
      .esriPopup.dark .esriPopupWrapper {
        border: none;
      .esriPopup .contentPane {
        text-align: center;
      .esriViewPopup .gallery {
        margin: 0 auto;
    </style>
    <script src="https://js.arcgis.com/3.15/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/dijit/Popup",  "esri/dijit/InfoWindow", "esri/dijit/PopupTemplate",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleFillSymbol", "esri/Color",
        "dojo/dom-class", "dojo/dom-construct", "dojo/on",
        "dojox/charting/Chart", "dojox/charting/themes/Dollar",
        "dojo/domReady!"
      ], function(
        Map,
        Popup, InfoWindow, PopupTemplate,
        FeatureLayer,
        SimpleFillSymbol, Color,
        domClass, domConstruct, on,
        Chart, theme
        //The popup is the default info window so you only need to create the popup and
        //assign it to the map if you want to change default properties. Here we are
        //noting that the specified title content should display in the header bar
        //and providing our own selection symbol for polygons.
        var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
        var infoWindow = new InfoWindow({}, domConstruct.create("div"));
        infoWindow.startup();
        var popup = new Popup({
            fillSymbol: fill,
            titleInBody: false
        //Add the dark theme which is customized further in the <style> tag at the top of this page
        domClass.add(popup.domNode, "dark");
        map = new Map("map", {
          basemap: "gray",
          center: [-98.57, 39.82],
          zoom: 4,
          infoWindow: popup
        map.on("click", function(evt){
            if(!evt.graphic){
                map.setInfoWindow(infoWindow); //This line is only needed if you want to switch the infoWindow
                //Change the content only if do not want to change the appearance of infoWindow.
                map.infoWindow.setContent("<div>I am no where</div>");
                map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
        var template = new PopupTemplate({
          title: "Boston Marathon 2013",
          description: "{STATE_NAME}:  {Percent_Fi} of starters finished",
          fieldInfos: [{ //define field infos so we can specify an alias
            fieldName: "Number_Ent",
            label: "Entrants"
            fieldName: "Number_Sta",
            label: "Starters"
            fieldName: "Number_Fin",
            label: "Finishers"
          mediaInfos:[{ //define the bar chart
            caption: "",
            type:"barchart",
            value:{
              theme: "Dollar",
              fields:["Number_Ent","Number_Sta","Number_Fin"]
        var featureLayer = new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Boston_Marathon/FeatureServer/0",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
          infoTemplate: template
        map.addLayer(featureLayer);
    </script>
  </head>
  <body class="claro">
    <div id="map"></div>
  </body>
</html>
Let me know if that help.
Enjoy!
TracySchloss
Honored Contributor
That does help, but it doesn't switch back.  Once you've change to the plainer infoWindow, it stays there.
I always use Popup, but in the case of the original example, which includes a tabContainer, a couple of content panes and a chart, it doesn't draw correctly until you specify infoWindow instead.  I stared at my setContent function for quite a while, assuming my problem was there, before I finally took a step back and looked elsewhere.
GirishYadav
oh yes, I quickly just compiled this code to show how can you change the infoWindow. However following is more complete example:
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        padding: 0;
        margin: 0;
        height: 100%;
        color: #A4CE67;
        border: none;
        text-align: center;
        margin: 0 auto;
    </style>
    <script>
      var map, defualtPopup;
      require([
        "esri/map",
        "dojo/domReady!"
      ], function(
        Map,
        FeatureLayer,
        Chart, theme
            fillSymbol: fill,
            titleInBody: false
          basemap: "gray",
          zoom: 4,
          infoWindow: popup
        defaultPopup = map.infoWindow;
            if(!evt.graphic){
            map.setInfoWindow(defaultPopup);
        popup.on("show", function(){
           infoWindow.hide();
            label: "Entrants"
            label: "Starters"
            label: "Finishers"
            caption: "",
            type:"barchart",
            value:{
              theme: "Dollar",
          outFields: ["*"],
    </script>
  </head>
  </body>
</html>
Girish
TracySchloss
Honored Contributor
That's better.  The tricky part will be that I don't just have two different layers.  I actually have multiple, some for points and some for polygons.  It seems like this might still work, but I'll have to test it with my actual data.
