Initial extent of work area in ArcGIS collector
2838
01-05-2016 09:18 AM
RandallClark2
Hi all,
What defines the initial extent of the "work area" that i am allowed to chose when i am taking a base map off line in collector?
Can that initial extent be changed? if so how? and why can i not chose a larger extent then what the initial extent is set too?
by Anonymous User
Not applicable
I was having the same issue. I was able to fix it by changing the extents of the layers that make up my base map in SDE. Then overwriting the map service.
