Hiding feature layer out side of boundary feature layer using javascript api
5667
10
12-30-2015 08:43 AM
KushendraShah1
I have a two feature layer; property boundary and pond layer. I am developing javascript application that shows the two layers. I made hollow to the polygon boundary layer that helps to see pond layer overlaid on it. However is there way I can just display the ponds inside the property boundary layer without displaying outside of boundary layer. Any reference or code samples will be appreciated. Thanks
JakeSkinner
Esri Esteemed Contributor
Yes, you can do this with polygon data.  You will just need to use the Polygon class rather than the Point class.  The below example selects all counties that intersect the state of Florida.
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Sample Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.15/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/layers/FeatureLayer",
        "esri/tasks/query", "esri/tasks/QueryTask",
        "esri/geometry/Polygon", "esri/SpatialReference",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "esri/graphic",
        "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/domReady!"
      ], function(
        Map, FeatureLayer,
        Query, QueryTask,
        Polygon, SpatialReference,
        SimpleFillSymbol, SimpleLineSymbol, Color, Graphic,
        dom, on, array
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-81.6182, 28.3678],
          zoom: 8
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2",{
            mode: FeatureLayer.MODE_SNAPSHOT,
            outFields: ["*"],
            opacity: 0.75
        featureLayer.setDefinitionExpression("state_name = 'Florida'");
        map.addLayer(featureLayer);
        var query = new Query();
        query.where = ["1=1"];
        featureLayer.queryFeatures(query, function(featureSet) {
          geometry = featureSet.features[0].geometry;
          var queryTask = new QueryTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/3");
          query.geometry = geometry;
          query.returnGeometry = true;
          queryTask.execute(query, function(graphic){
            array.forEach(graphic.features, function(feature){
                var polygonJson = {"rings": feature.geometry.rings, "spatialReference":{"wkid":4326}};
                var polygon = new Polygon(polygonJson);
                var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
                    new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,
                    new Color([255,0,0]), 2),new Color([255,255,0,0.25])
                var graphic = new Graphic(polygon, sfs);
                map.graphics.add(graphic);
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
TimWitt2
Hey Kushendra,
I think the only way to do this, is by running a query and selecting all ponds that are within a certain Polygon.
ArcGIS API for JavaScript Sandbox  instead of the buffer polygon use your polygon.
Once they are selected make the symbology for the ponds that are not selected invisible and the symbology for the selected features what ever you like.
FeatureLayer | API Reference | ArcGIS API for JavaScript
Hope this helps
Tim
KushendraShah1
Thanks for the info Tim. I was looking for script where I can interact with feature content to filter out the data on the client side.
JakeSkinner
Hi Kushendra,
Below is an example.  Using the QueryTask function, only the cities are returned that intersect Miami-Dade county.
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script>
      var map;
      require([
        "esri/geometry/Point", "esri/SpatialReference",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "esri/graphic",
      ], function(
        Map, FeatureLayer,
        Query, QueryTask,
        Point, SpatialReference,
        SimpleMarkerSymbol, SimpleLineSymbol, Color, Graphic,
        dom, on, array
          basemap: "streets",
          center: [-81.792107, 26.150807],
          zoom: 8
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/3",{
            outFields: ["*"],
            opacity: 0.75
        featureLayer.setDefinitionExpression("name = 'Miami-Dade'");
          var queryTask = new QueryTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0");
                var point = new Point(feature.geometry.x, feature.geometry.y, new SpatialReference({wkid:4326}));
                var simpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10,
                    new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
                    new Color([255,0,0]), 1),
                    new Color([0,255,0,0.25]));
                var graphic = new Graphic(point, simpleMarkerSymbol);
    </script>
  </head>
  <body>
  </body>
</html>
KushendraShah1
Jake- that is great. This is something I need however, I experience problem on retrieving the exact polygon geometries. Is there way I can return polygon geometry ( not points) from the feature data that intersect with other polygon layer? In my data, there are numerous property boundaries (polygons) and I need to filter out ponds (polygon)  in order to display only within those boundaries. I would be glad to get code snippets if you have. Thank you and appreciated your help
JakeSkinner
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script>
      var map;
      require([
      ], function(
        Map, FeatureLayer,
        Query, QueryTask,
        dom, on, array
          basemap: "streets",
          zoom: 8
            outFields: ["*"],
            opacity: 0.75
    </script>
  </head>
  <body>
  </body>
</html>
KushendraShah1
Jake I did exactly the way you did but still it did not return the pond geometries. In addition, do I need to add layer to display pond layer? It has only displayed boundary layer. You can check the script and let me know if I need anything.
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script>
      var map;
      require([
      ], function(
        Map, FeatureLayer,
        Query, QueryTask,
        dom, on, array
          basemap: "topo",
          center: [-97.144, 34.174],
          zoom: 8
        var featureLayer = new FeatureLayer("http:xxxx/webgis/rest/services/Cooperators/cooperatorboundaryandpond/FeatureServer/0",{
            outFields: ["*"],
            opacity: 0.75
        featureLayer.setDefinitionExpression("EntityID = '9410'");
          var queryTask = new QueryTask("http:xxxx/webgis/rest/services/Cooperators/cooperatorboundaryandpond/FeatureServer/1");
                var polygonJson = {"rings": feature.geometry.rings, "SpatialReference":{wkid:102725}};
    </script>
  </head>
  <body>
  </body>
</html>
JakeSkinner
Are there any errors reported in the console window (click F12 on your keyboard to open)?
KushendraShah1
I did not see any errors jake. Can you check here if anything is missing? Edit fiddle - JSFiddle
JakeSkinner
Everything looks correct, but I don't think I'll be able to determine the issue without having access to the services.
