Access database has points and areas in the same table
3003
12-24-2015 01:37 PM
EninnaLuli1
I have an Access database which has points and areas in the same table.
The records that are area have multiple longitude and latitudes (I am guessing each would be a point which would form polygons).
The fields are called StartLong, StartLat, StartLongWGS84, StartLatWGS84, EndLat, EndLong, etc. Am I able to make this into a shapefile? If so, how?
(I would have to split the table into two: points and area before converting to shapefile since a shapefile can only be one type of geometry).
DanPatterson_Retired
to make a point file Adding x,y coordinate data as a layer—Help | ArcGIS for Desktop
for a line file XY To Line—Help | ArcGIS for Desktop
skip the polygon file, it isn't going to happen
