Layer Swipe Slide Bar / Slide Handle Not Displaying
4811
12-17-2015 02:02 PM
Kathleen_Crombez
I am wondering if something changed on the layer swipe widget today?
Yesterday everything was working fine. But today I am experiencing the following issue.
When I initialize the map I call a function to create the layer swipe widget.
It loads and everything works fine.
But I have a check box to toggle the swipe tool and a drop down list to select the swipe layer.
When either of these are used I call the destroy() method on the widget and create a new widget using the exact same function that creates it in the map initialization.
When the startup() method is called this time the slider bar and slider handle is missing.
I thought it might have been something I changed that messed it up. But then I noticed the esri sample was experiencing the same issue.
http://esri.github.io/arcgis-dijit-layer-swipe-js/
The weird thing is... The layer loads and is positioned correctly and I see the widget is created in Firebug.
The other weird thing is when I call destroy(), it removes my swipe div from the dom.
swipe widget is there on map load.
swipe widget (and hard coded div) are gone after destroy() / startup() sequence.
HTML
<div id="map" class="tundra" style="overflow: hidden;">
     <div id="swipeDiv"></div>
</div>
<label for="swipeLayer">Swipe Layer:</label>
<select id="swipeLayer" style="width: 110px;" onchange="swipeLayer_Changed();">
     <option value="CO2014" selected="selected">2014 Aerial</option>
     <option value="CO2011">2011 Aerial</option>
     <option value="CO2008">2008 Aerial</option>
     <option value="CO2005">2005 Aerial</option>
     <option value="CO2002">2002 Aerial</option>
     <option value="CO1988">1988 Aerial</option>
     <option value="CO1973">1973 Aerial</option>
</select>
<input id="swipeBox" type="checkbox" checked="checked" aria-checked="true" onchange="swipeBox_Changed(this);" />
<label for="swipeBox">Swipe Aerial Image</label>
Javascript
    var swipeLeft = 200;
    var swipeIndex;
    var swipeLayers = [];
    var swipeWidget;
    var imageDict = {};
    var urlDict = {};
    var swipeChecked = true; // used in print function to hide swipe layer
    function initImageDict() { // called in mapinit
        imageDict["CO2014"] = [CO2014LO];
        imageDict["CO2011"] = [CO2011HI, CO2011LO];
        imageDict["CO2008"] = [CO2008HI, CO2008LO];
        imageDict["CO2005"] = [CO2005HI, CO2005LO];
        imageDict["CO2002"] = [CO2002HI, CO2002LO];
        imageDict["CO1988"] = [CO1988HI, CO1988LO];
        imageDict["CO1973"] = [CO1973HI, CO1973LO];
        initUrlDict();
    function initUrlDict() {
        urlDict["CO2014"] = [CO2014LO_url];
        urlDict["CO2011"] = [CO2011HI_url, CO2011LO_url];
        urlDict["CO2008"] = [CO2008HI_url, CO2008LO_url];
        urlDict["CO2005"] = [CO2005HI_url, CO2005LO_url];
        urlDict["CO2002"] = [CO2002HI_url, CO2002LO_url];
        urlDict["CO1988"] = [CO1988HI_url, CO1988LO_url];
        urlDict["CO1973"] = [CO1973HI_url, CO1973LO_url];
    function swipeLayer_Changed() {
        require(["esri/dijit/LayerSwipe", "esri/layers/ArcGISImageServiceLayer"
        ], function (LayerSwipe, ArcGISImageServiceLayer) {
            if (swipeWidget) {
                swipeWidget.destroy();
            for (var i = 0; i < swipeLayers.length; i++) {
                map.removeLayer(swipeLayers);
            swipeLayers = [];
            // initiate the swipe tool
            if (swipeChecked) {
                var swipeLayer = document.getElementById("swipeLayer").value;
                var urls = urlDict[swipeLayer];
                for (var i = 0; i < urls.length; i++) {
                    var layer = initImageLayer(ArcGISImageServiceLayer, urlDict[swipeLayer], "swipe" + String(i), 1.0);
                    map.reorderLayer(layer, swipeIndex + i);
                    layer.show();
                    swipeLayers.push(layer);
                swipeWidget = new LayerSwipe({
                    type: "vertical",  //Try switching to "scope" or "horizontal"
                    left: swipeLeft,
                    map: map,
                    layers: swipeLayers
                }, "swipeDiv");
                swipeWidget.startup();
                swipeWidget.on("swipe", function (swipeObject) {
                    swipeLeft = swipeObject.left;
    function swipeBox_Changed(checkbox) {
        if (checkbox.checked) {
        else {
            swipeChecked = false;
        document.getElementById(checkbox.id).setAttribute("aria-checked", checkbox.checked);
Has any one else been experiencing this behavior? I had it working perfectly yesterday. And all I did today was add some aria labels.
Maybe I have a syntax error and I am just over looking it.
Thanks.
Kathleen_Crombez
Well...
I don't know what caused the sudden issue.
But I found a work around to the div being deleted.
I simply create a div dynamically to attach the layer swipe widget to. (in bold below).I also found that the swipeWidget.on("swipe") always returns 0 for left, so I removed that.
Here is the new function.
            if (swipeWidget) {
            swipeLayers = [];
            if (swipeChecked) {
                var swipeContainer = document.getElementById("swipeContainer");
                if (!swipeContainer) {
                    swipeContainer = document.createElement("div");
                    swipeContainer.id = "swipeContainer";
                    var swipeDiv = document.getElementById("swipeDiv");
                    swipeDiv.appendChild(swipeContainer);
                    layer.show();
                    left: 155,
                    map: map,
                    layers: swipeLayers
                }, "swipeContainer");
Kathleen_Crombez
Well...
            if (swipeWidget) {
            swipeLayers = [];
            if (swipeChecked) {
                    layer.show();
                    left: 155,
                    map: map,
                    layers: swipeLayers
