Python Toolbox Help
5964
8
12-17-2015 08:55 AM
MaryM
I am trying to create my first Python Toolbox.  I have tons of ACS text file, comma field separated files.  I want my users to easily be able to join the tables to the geometry file.  My first parameter, the list of available text files is working.  Then, when I add the next parameter for the users to pick which fields they want to join from the text file as a check list is not working.  Not sure how to set this up the parameters properly?  Any help is much appreciated?
import arcpy
import os
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "ACS_2013_5Year_Toolbox"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [ACSJoinTableTool]
class ACSJoinTableTool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Join ACS Table to Census Block Group Geometry"
        self.description = "Pick a table to temporarily join to the" + \
                                     "Block Group GIS layer."
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        #Make parameter #0 a list of the ACS text files.
        filterList = []
        fol = r"---file path of folder containing text files here---"
        for i in os.listdir(fol):
            if i.split(".")[-1].find("txt") != -1:
                x = i.split(".")[0]
                filterList.append(x)
        filterList.sort()
        param0 = arcpy.Parameter(displayName = "Pick Table:",
                  name = "in_table",
                  datatype="GPString",
                  parameterType="Required",
                  direction="Input")
                  param0.filter.list = filterList
        #Make parameter #1 a list of the table columns
        joinTable = os.path.join(r"---file path of folder containing text files here---", param[0].valueAsText + ".txt")
        pickedTable = open(jointable,"r")
        pickedTableFields = pickedTable.readline()
        pickedTableFields = pickedTableFields.replace(",",";")
        param1 = arcpy.Parameter(displayName = "Pick Join Fields:",
                  name = "in_fields",
                  parameterType="Derived",
                  direction="Input")
         param1.parameterDependencies = [param0.value]
         param1.filter.list = pickedTableFields
         parameters = [param0,param1]
          return parameters
Tags (1)
MaryM
I figured out how to make it work in a Python Toolbox...
import arcpy
import os
    def __init__(self):
        .pyt file)."""
        self.alias = ""
    def __init__(self):
        #Make parameter #0 a drop down list of the ACS text files and user can pick one
        filterList = []
        fol = r"---Path of Folder Containing ACS Text Files Here----"
                x = i.split(".")[0]
        filterList.sort()
                                                      name = "in_table",
                                                      direction="Output")
      #Make parameter #1 filter multi-value check list a of the table columns, the user can check multiple columns
      pickTableFieldsList=[]
                                                      name = "in_fields",
                                                      datatype= "GPString",
                                                      parameterType= "Required",
                                                      direction= "Input",
                                                       multiValue=True)
      param1.filter.type = "ValueList"
      param1.filter.list = pickTableFieldsList
      return parameters
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        #When the 0th parameter gets a value the field headers (1st column in text file) are available to select
        if parameters[0].value:
            joinTable = os.path.join(r"---Folder Containing ACS Text Files Here", parameters[0].valueAsText + ".txt")
            pickedTable = open(joinTable,"r")
            pickedTableFieldsString = pickedTable.readline()
            pickedTableFieldsString = pickedTableFieldsString.replace("\n","")
            pickedTable.close()
            pickedTableFieldsList = pickedTableFieldsString.split(",")
            parameters[1].filter.list = pickedTableFieldsList
        return
DanPatterson_Retired
Mary, you might want to slide this a bit deeper into the Developer Space to pickup the Python place
GeoNet Community Structure
Python
WesMiller
Dan Patterson​ you had(a long time ago) the best example for linking python scripts to a tool box that had a well documented script and a tool box. Do you still have it, would be willing to share again?
Wes Miller    On the iThingy and not able to access my desktop for a while.  The example to which you refer, I am pretty sure was for a conventional toolbox and not one of these python toolboxes (which are often a bit of an overkill most times).  Most of what I see in the script could be substituted with 2 getparametersastext or sys.argvs then define the parameter type, direction, obtained from etc in the tool's properties.
Setting script tool parameters—Help | ArcGIS for Desktop
MaryM
I could easily set this task up in a script tool.  Part of this is I am trying to learn how to write a Python Toolbox.  I have not recognized by using the help how to do this correctly.
WesMiller
For python toolbox Defining parameters in a Python toolbox—Help | ArcGIS for Desktop
For script tool
Basically you use in your script someVar = arcpy.GetParameterAsText(0) then set them to correspond in your tool properties.
MaryM
import arcpy
import os
    def __init__(self):
        .pyt file)."""
        self.alias = ""
    def __init__(self):
        filterList = []
                x = i.split(".")[0]
        filterList.sort()
                                                      name = "in_table",
                                                      direction="Output")
                                                      name = "in_fields",
                                                      direction= "Input",
                                                       multiValue=True)
      return parameters
        return True
            pickedTable.close()
        return
WesMiller
I found this today you may find it useful.
Toolbox to Python Toolbox Wrapper
http://www.arcgis.com/home/item.html?id=83585412edd04ae48bdffea3e1f7b2e7
