programmatically add/remove splitter, resize a contentpane
4272
12-14-2015 09:05 AM
TracySchloss
Honored Contributor
I have a footer as a contentPane defined as
<div id="footer" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'">
I have a buffer tool based on a button click that will open a grid in the footer.  Until that tool is activated, I'd rather not see the footer at all.  Not only do I want to set a height to it, but I also want to set the splitter property on it.
I thought I could use dom-style like
domStyle.set("footer", "splitter", "true"), and also set the height this way, but it doesn't work.
KellyHutchins
Esri Notable Contributor
Here's some sample code that shows how to open a dojo content pane based on some condition. In this example if you click on a line feature then click the 'elevation profile' link at the bottom of the popup the elevation profile chart appears in a content pane.
Here's a jsbin showing the code and I've also attached as a zip.
JS Bin - Collaborative JavaScript Debugging
KellyHutchins
TracySchloss
Honored Contributor
That works great, thanks Kelly.
