How can i change background color of map view on IOS?
3946
12-08-2015 03:35 AM
UygarTarakci
I am using TiledMapServiceLayer to load a map in map view. There are no other layers.When i try to change background color of mapview to a color with pattern image or to clear nothing changes and becomes black again as default, but when i try to use another color like red or blue it works.How can i change it to a pattern image or to clear so i can show the image in the background of the map? and as a follow up question can i remove the grid from tiled layer or make it invisible?
Thank you for your help.
