Export to pdf:Using ArcGIS Runtime sdk for Qt 10.2.6(c++)
4147
12-07-2015 04:03 AM
kishorekumar1
Is it possible to export to PDF for high resolution local printing of any map view using ArcGIS Runtime sdk for Qt 10.2.6(c++).
Regards,
Kishore Kumar
Tags (1)
LucasDanzinger
Esri Frequent Contributor
Hi Kishore,
There is almost certainly a way to do this with Qt itself, but we do not have any methods baked into the API for this. At Quartz, we will have a way to export images from a map view, but actually exporting to PDF won't be an option even at Quartz. I believe you will need to look into using the QPrinter class from Qt - QPrinter Class | Qt Print Support 5.5
Luke
LucasDanzinger
Hi Kishore,
Luke
