Disable tools in tool bar
3025
11-27-2015 02:43 AM
ADITYAKUMAR1
Hi User,
  I have a toolbar and I have added some more tools into it. The issue is coming when I am using my added tools.By default all the other tools should get disabled when I am using any one tool.But for the tools I have added its not working.
How to make it work?
navToolbar = new Navigation(map);
          on(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
          on(map, "update-start", showLoading);
          on(map, "update-end", hideLoading);
          registry.byId("zoomin").on("click", function () {
              navToolbar.activate(Navigation.ZOOM_IN);
          registry.byId("zoomout").on("click", function () {
              navToolbar.activate(Navigation.ZOOM_OUT);
          registry.byId("zoomfullext").on("click", function () {
              navToolbar.zoomToFullExtent();
          registry.byId("zoomprev").on("click", function () {
              navToolbar.zoomToPrevExtent();
          registry.byId("zoomnext").on("click", function () {
              navToolbar.zoomToNextExtent();
          registry.byId("pan").on("click", function () {
              navToolbar.activate(Navigation.PAN);
          registry.byId("buffer").on("click", function () {
              //document.getElementById('bufferdiv').style.display = "block";
              var e = document.getElementById('bufferdiv');
              if (e.style.display == 'block')
                  e.style.display = 'none';
              else
                  e.style.display = 'block';
          registry.byId("identify").on("click", function () {
              var e = document.getElementById('polygondiv');
              else
          registry.byId("deactivate").on("click", function () {
              navToolbar.deactivate();
  <div id="navToolbar" data-dojo-type="dijit/Toolbar">
        <div data-dojo-type="dijit/form/Button" id="zoomin" data-dojo-props="iconClass:'zoominIcon'">
        </div>
        <div data-dojo-type="dijit/form/Button" id="zoomout" data-dojo-props="iconClass:'zoomoutIcon'">
        </div>
        <div data-dojo-type="dijit/form/Button" id="zoomfullext" data-dojo-props="iconClass:'zoomfullextIcon'">
        </div>
        <div data-dojo-type="dijit/form/Button" id="zoomprev" data-dojo-props="iconClass:'zoomprevIcon'">
        </div>
        <div data-dojo-type="dijit/form/Button" id="zoomnext" data-dojo-props="iconClass:'zoomnextIcon'">
        </div>
        <div data-dojo-type="dijit/form/Button" id="pan" data-dojo-props="iconClass:'panIcon'">
        </div>
        <input type="image" class="measure" onclick="show(titlePane)" src="http://localhost/map/measure.jpg"
            alt="HTML5" />
        <input type="image" class="maptips" onclick="maptips()" src="http://www.computerhope.com/jargon/r/refresh.jpg"
            alt="HTML5" />
        <!--input type="image" class="buffer" onclick="buffer()" src="http://graffitialphabet.org/letter-b/blue-graffiti-alphabet-b.jpg"
            alt="HTML5" /-->
            <div data-dojo-type="dijit/form/Button" id="buffer" data-dojo-props="iconClass:'buffer'">
        </div>
          <div data-dojo-type="dijit/form/Button" id="identify" data-dojo-props="iconClass:'identify'">
        </div>
        <input type="image" class="remove" onclick="map.graphics.clear(graphic)" src="http://rebuildcreditscores.com/wp-content/uploads/2013/02/charge-remove-question-from-consumer.jpg"
            alt="HTML5" />
        <div data-dojo-type="dijit/form/Button" id="deactivate" onclick="hide(titlePane)"
            data-dojo-props="iconClass:'deactivateIcon'">
        </div>
    </div>
Aditya Kumar
RobertScheitlin__GISP
Aditya,
   You would have to use "dijit/form/ToggleButton" and not "dijit/form/Button" then.
