Calculate orthogonal Lines of a given Line
5990
10
11-18-2015 03:34 AM
JohannesBierer
Any ideas to do this. In arcpy?
In a given distance.
DanPatterson_Retired
You can get the normal (angle, point, distance) from the outputs of Near—Help | ArcGIS for Desktop and construct your normal segments accordingly...unless you want to do this in pure python?
JohannesBierer
Don't really get it? I would like to calculate cross direction profile of one line with a dem?
a normal is a line at 90 degrees to another line as in a profile or cross-section etc.  Are you trying to create those? or are you just wanting lines across features?
your link is no good, it goes to the geonet home page.
LukeSturtevant
Are you trying to generate cross sections on a river centerline?
RebeccaStrauch__GISP
Luke Sturtevant , I might like to do something like that if you have a link or suggestions.....not wanting to hijack this post though, so if not a simple link and/or that isn't what the OP wanted, I can branch off to another post.  That maybe will help on  a project I am doing now.
LukeSturtevant
Rebecca the current tool I have is attached. The code definitely works and does the same thing that Darren's code does, but it is not as compact as his code. I'm definitely going to update the tool to incorporate his more concise coding. Anyway, the tool generates perpendicular cross sections and also ensures that all cross sections are pointing from left to right looking downstream.
On another note, I hope this kills two birds with one stone, but we have not heard from Johannes.
Thanks Luke.  I'm going to check out both scripts, but my actual need might be more of a drainage/contour "parallel" flight line/transect.  I have thoughts on that already....project lead still trying to figure out what hereally wants.
As for Johannes....time zone might be different.
DarrenWiens2
If you have ET GeoWizards, the tool to generate perpendicular lines is Create Station Lines.
Or, you can use arcpy geometry objects, as outlined in this thread.
