How to implement geofence using ArcGIS javascript api
6959
11-16-2015 03:29 AM
absarhasan
I have created a map using  ArcGIS​​ javascript api, and searching for geofencing implementation with javascript api for Cordova application with notification on enter/out in geofence area but not found any related document. Is there any way to implement geofencing using javascript apis? any example? documentation?
ChrisSmith7
Honored Contributor
You should probably check-out the GeoTrigger API:
Geotrigger API Reference | ArcGIS for Developers
Here's the service homepage:
Geotrigger Service | ArcGIS for Developers
absarhasan
Yes I have used javascript geotrigger apis for creating geofence like sample code
var geo = geotriggers.request("trigger/create", {
                condition: {
                    direction: "enter",
                    geo: {
                        latitude: evt.result.feature.geometry.getLatitude(),
                        longitude: evt.result.feature.geometry.getLongitude(),
                        distance: $scope.radius
                action: {
                    notification: {
                        text: "Welcome to my world"
                setTags: ["device:" + geotriggers.deviceId]
            }, function(error, response, xhr) {
                console.log(response);
                //var radius = 2000;
                var circle = new Circle({
                    center: [result.getLongitude(), result.getLatitude()],
                    geodesic: true,
                    radius: $scope.radius
                            //radiusUnit: "esriMiles"
                var circleSymb = new SimpleFillSymbol(
                        SimpleFillSymbol.STYLE_SOLID,
                        new SimpleLineSymbol("solid", new Color([232, 104, 80]), 2),
                        new Color([232, 104, 80, 0.25])
                var graphicc = new Graphic(circle, circleSymb);
                map.graphics.add(graphicc);
                geotriggers.request("location/last", {
                    //tags: ["portland", "trigger:0a40d32c822f6fa15e3bb255a03867f1"],
                    //triggerIds:['0a40d32c822f6fa15e3bb255a03867f1'],
                    //"deviceIds":['bBpZcWnu5l3xb0dl']
                    console.log(error, response, xhr);
                geotriggers.request("trigger/run", {
                    tags: ["device:" + geotriggers.deviceId]
and then notify the updated status using
geotriggers.request("device/notify",
                        // dryRun: true,
                        "tags": ["device:" + geotriggers.deviceId],
                        "geo": {
                            "latitude": 18.50897704100,
                            "longitude": 73.82487596500052
                        "deviceIds": [geotriggers.deviceId]
                // alert(JSON.stringify(response));
but here after I am not able to find any document for implementation in map and get notification when it breaks geofence.
There are steps for android and ios with SDK  but not found any for javascript for hybrid mobile implementation.
And at last I want to be confirmed that is gefencing if posiible using javascript apis?
