Edit-Using the attribute inspector
5211
7
11-13-2015 11:03 AM
RickeyFight
I got this Sample  to work and configured using my own service.
I have now tried to add it to another script.
Here is my complete code so far JS Bin - Collaborative JavaScript Debugging
The popup should allow me to edit but nothing shows up.
I feel like I am missing some small thing.
Thank you
TracySchloss
Honored Contributor
Everything you want to edit is added as a FeatureServer, not MapServer?   Also check that all attributes you want to edit are listed as outFields for that layer.
RickeyFight
Tracy,
I have added a FeatureServer, and I have outFields: ["*"]. So all fields should available.
TracySchloss
Honored Contributor
Check how your adding your layers -  map.addLayer.   You're listening for layers-add-result (plural),so nothing ever triggers it.   I'd change it to map.addLayers adding your layers in an array.  Then your function should execute.
RickeyFight
Tracy,
I have changed the addLayer and it does not effect the app.
TracySchloss
Honored Contributor
Also, I don't see where you required AttributeInspector.
RickeyFight
I did not have AttributeInspector, it must have been missed when I moved code.
I have now included it. I am still getting nothing to display in popup.
RickeyFight
This is my current error
