On Edit Complete
7644
9
11-16-2015 09:20 AM
MeleKoneya
I am using the Edit Widget and the Batch Attribute Editor widget to edit our Feature Layer.     I would like to be able to modify two attributes when the Edit is Complete with these widgets.    I would like to update a date field and a user field.    I know this can be done via the Editor Tracking Fields,  but the layer is edited in ArcMap and I only want to update the attributes when an edit occurs via WAB.     Is there a place in WAB where I can put some custom code to set these attributes when an edit is compete?
Mele
LizDaRos
Mele,
I asked this same kind of question a few weeks ago and Robert suggested adding these lines to the _worksAfterCreate: function which is in the Edit Widget.js.
//Add the autopopulate field value
        this.editor.templatePicker.on("selection-change", lang.hitch(this, function() {
          var selected = this.editor.templatePicker.getSelected();
          if (selected) {
            var featureLayer = selected.featureLayer;
            on.once(featureLayer, "before-apply-edits", lang.hitch(this, function(evt){
              if(evt.adds && evt.adds.length > 0){
                if(evt.adds[0].attributes.hasOwnProperty('Begin_Date_Occ')){
                  evt.adds[0].attributes.Begin_Date_Occ = new Date(Date.now());
                this.editor.attributeInspector.refresh();
//End add
This only works when creating new features so if you are just updating attributes of already created features these fields will not auto-populate, I'm still trying to fix that. Maybe you could remove the this.editor.attributeInspector.refresh(); line so it does not show the auto-populated fields.
Here's the link to my question for more information.
LizDaRos
Mele,
          if (selected) {
//End add
AlejandroCosci
Hello Mele;
Just a quick question...
I have same prom like you, I need update same fields during edit occurs.
Did you solve this issue?
Regards,
Alejandro Cosci
MeleKoneya
Alejandro,
I did solve this issue using the code that Liz provided which Robert had suggested.
Let me know if you have any questions on how I implemented this.
Mele
AlejandroCosci
Thanks for your quick answer Mele!
Yes I had some problems to adapt the solution of Liz to my project.
As the USR draws a polygon, I need to update a field with a global var to populate a specific field(USR_ID).
If you have an example for this I would really appreciate it.
Regards,
Alejandro
MeleKoneya
Alejandro,
This my complete code.
_worksAfterCreate: function () {
       //debugger;
          if (selected) {
                if(evt.adds[0].attributes.hasOwnProperty('sfd_status')){
                  evt.adds[0].attributes.sfd_status = "NOT FLUSHED";
                if (evt.adds[0].attributes.hasOwnProperty('sfd_edit_by')){
                  evt.adds[0].attributes.sfd_edit_by = StationShift;
                 if (evt.adds[0].attributes.hasOwnProperty('sfd_edit_date')){
                  evt.adds[0].attributes.sfd_edit_date = convertUTCDateToLocalDate(new Date(Date.now()));
                refreshLayers(this.map, this.map.graphicsLayerIds);
The section that may be most applicable to your situation is where I have a field called  'sfd_edit_by' that I am populating with my 'StationShift' variable defined elsewhere.
AlejandroCosci
Thanks for your help Mele!
After several test we could use the code that you provide me.
But with some changes:
I added the code into _addButtonToInspector: function() not into _worksAfterCreate: function()
And remove the line:
refreshLayers(this.map, this.map.graphicsLayerIds);  It did not work on my code.
Again, thanks a lot for your help!
Alejandro Cosci
MeleKoneya
Alejandro,
I am grateful to Liz and Robert for their help and I am glad their assistance to me was also of use to you.
Mele
Robert Scheitlin, GISP
JoseSanchez
Hello everyone,
I am also using the Edit Widget and I need to autopopulate fields in my code.
The application creates a new polygon layer with 2 variations: one blue and another green.
To start I just added to the source code  ..\widgets\Edit\Widget.js and 2 alerts
on the events:
   _worksAfterCreate: Alert("_worksAfterCreate")
_worksBeforeCreate: Alert("_worksAfterCreate")
Both alerts display before the Edit Widget window show all its components. Before the drawing tools part to select a polygons are visible inside Edit Widget window.
Also I just added the code from this post to update one field but it does not work
This is my question:
After selecting a shape to draw a new polygon with the  Edit Widget it pops up a new window to enter attributes (attribute inspector) . I have to click on the button close in the attribute inspector to save all the values entered on the attributes, but the event _worksAfterCreated is not called from the Attribute Inspector anymore.
_worksAfterCreate: function(settings) {
        // add close button to atiInspector
        this._addButtonToInspector();
        // disable delete button in the toolbar
        if(this._configEditor.toolbarVisible) {
          this._disableDeleteBtnInToolbar();
        // resize editPopup
        this.editPopup.resize(300, 251);
        // update templatePicker for responsive.
        this.editor.templatePicker.update(true);
        // // reset default selectionSymbol that change by Editor dijit.
        // array.forEach(this.editor.settings.layerInfos, function(layerInfo) {
        //   layerInfo.featureLayer.setSelectionSymbol();
        // }, this);
                                //Customized Code for the AutoPopulated fields
                                alert("_worksAfterCreate ");
          if (selected) {
                if(evt.adds[0].attributes.hasOwnProperty('ID')){
                  evt.adds[0].attributes.ID = 1);
JoseSanchez
Just to let you know that the code works  in the _worksAfterCreate:  event.
