Export Data Grid to CSV after querying
4970
11-13-2015 09:36 AM
AlexGole
Hi all, I wondered if someone had a good on how to export a data grid to csv file after query. I would like something like this but this fiddle does not seem to work. Also  instead of the findTask, I use a simple queryTask. Any idea is welcome. Thanks,
Alex
function addToMap3(results) {
                             // make sure both queries finished successfully
                             map.graphics.clear();
                             var featureArray = results.features;
                             if (featureArray && featureArray.length > 0) {
                                 // do stuff with the features
                                 arrayUtils.forEach(featureArray, function (feat) {
                                     feat.setSymbol(symbol8);
                                     map.graphics.add(feat);
                                 var extent = esri.graphicsExtent(map.graphics.graphics);
                                 map.setExtent(extent, true);
                             } else {
                                 // do stuff when no features were found
                                 alert("No features found")
TracySchloss
Honored Contributor
There are a lot of pieces to this, including a server-side script needed to create the output file  I got mine from:
Export dojo datagrid results to csv in javascript web application - Geographic Information Systems S...
I made subfolder in my project, which I called webservices. The script is  csv.ashx.
You will need a form to manage the interaction with this script.  It's not something you display, but you still need it.
  You will need to add a hidden form to access this.
        <div id="downloadForm" data-dojo-type="dijit/form/Form" method="post" action="webservices/csv.ashx" target="_blank">
            <input type="hidden" name="report" id="reportinput" value="" /><input type="hidden" name="filename" id="filename" value="" />
        </div>
In my project generating the contents of my grid dynamically, placing a 'Save' button above it.  You could just have a button that calls it more directly.
                var saveButton1 = new Button({
                  label: "Save List",
                  onClick: function(){
                    myCSV.saveGridCSV(grid);//existing grid is passed to the saveGridCSV function
                }, "btnSave");
This is my script.  I have two different grids and since they are dynamic, I needed code to generate the appropriate output name.  You wouldn't necessarily need that part.
//function for saving the grid contents to a CSV output file
define([
"dojo/on",
"dojo/dom",
"dijit/registry",
"dojo/_base/array"],
function(on, dom, registry, arrayUtils){
    return {
        saveGridCSV: function(gridData){
            var fName;
            var fieldNames = [];
            var dataArray = [];
            if (gridData) {
                var gridLength = gridData.store.data.length;
                dataArray.length = 0;
                fieldNames.length = 0;
                var fieldValue = "";
              // var gridColumns = gridData.columns;
                for (var col in gridData.columns) {
                    fieldNames.push(col);
                var lastCol = fieldNames.length - 1;
                var lastField = fieldNames[lastCol];
                dataArray.push(fieldNames.toString() + " \n");
                var gridStore = gridData.store;
                for (var i = 0; i < gridLength; i++) {
                    var gridRow = gridStore.data;
                    arrayUtils.forEach(fieldNames, function(fieldName){
                        fieldValue = gridRow[fieldName];
                        var stringValue = String(fieldValue);
                        if (stringValue.indexOf(",") > 0) { //removes any commas from data
                            stringValue = stringValue.replace(/,/g, " ");
                        if (stringValue.indexOf('\'') != -1 || stringValue.indexOf('\"') != -1) { //removes any slashes from data
                            //  console.log ("Data has a slash in it. Not sure of this section of the code!");
                            if (stringValue.indexOf('\"') != -1) {
                                stringValue = stringValue.replace("\"", "\"\"");
                            stringValue = "\"" + stringValue + "\"";
                        if (fieldName == lastField) {
                            dataArray.push(stringValue + " \n");//adds a new line when value is from the last field
                        else {
                            dataArray.push(stringValue);//otherwise just adds the value
                }//one row pushed to array
                var data = dataArray.join();
                var inputData = data.replace(/\n,/g, "\n");//some clean up to get rid of the leading commas in the data
                submitCSVprint(gridData.id, inputData);
            else { //nothing to save
                alert("Error saving data.");
            function submitCSVprint(gridName, inputData){
                var f = registry.byId("downloadForm");
                dom.byId("reportinput").value = inputData;
                var outFileName = setOutName(gridName);
                dom.byId("filename").value = outFileName;
                //    console.log(inputData);
                f.submit();
            function setOutName(gridName){
                var outFileName;
                var countyString1 = countyName.replace(". ", "_");
                var countyString = countyString1.replace(" ", "_");
                switch (gridName) {
                    case "offSatGrid":
                        outFileName = countyString + "_WIC_agency";
                        break;
                    case "venGrid":
                        outFileName = countyString + "_WIC_store";
                        break;
                return outFileName;
Here the link to my current project. I haven't gone to production yet with the most recent updates, which include separate my code into modules, as described here, but I didn't change the functionality.
Select any county from the dropdown and a list of sites available in that county is generated.  You can either save the list or open the map to that county.
Find WIC Locations by County
TracySchloss
Honored Contributor
        </div>
                  label: "Save List",
                }, "btnSave");
define([
"dojo/on",
"dojo/dom",
"dijit/registry",
    return {
            var fName;
            var dataArray = [];
            if (gridData) {
                        else {
                f.submit();
                var outFileName;
                switch (gridName) {
                    case "offSatGrid":
                        break;
                    case "venGrid":
                        break;
                return outFileName;
AlexGole
Thank you! That will be helpful
