creating 2 maps in 1 mxd file
5666
14
11-13-2015 06:57 AM
MikeHenson
so I am new at creating display maps in Arcmap. I have a file with all the layers I need in it.  I need to print 2 different scenarios within that file.  Is there a way to create 2 different maps in that file, as opposed to making a copy of the mxd file? Thanks for any help you can give.
Mike
DavidBarnes
Do you mean 2 different layouts in one mxd? An mxd always has exactly one layout. No more, no less. ArcGIS Pro can have any number of layouts, from none to as many as you can get in before computer limitations set in, such as memory.
MikeHenson
yes I mean multiple layouts. Coming from a cad background, I can create multiple printouts/layouts from one cad file. Guess thats not possible in arcmap? Thanks
JoshPritt
You mean you want to zoom to a certain area/scale, print it to PDF/paper, then zoom/pan to another area/scale and then print that one?  If so, then you just need to add another data frame to your layout.  We use this all the time in ArcFM to show the close up of a switch cabinet for electric networks.
ArcGIS Desktop Help - Using Data Frames.
DanPatterson_Retired
you can drag the elements off the layout that belong to one dataframe and drag on the elements of another data frame and print...pain I know, but Pro is finally returning the capabilities that we had a decade or so with Arcview 3.x
ChrisDonohue__GISP
Multiple layouts was a much-liked feature of ArcView 3.x, the predecessor to ArcMap.  However, ArcMap does not support multiple layouts.  There has been talk from time to time about ESRI re-implementing this.
Meanwhile, one potential workaround in ArcMap to check out is to use Data Drive Pages:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Chris Donohue, GISP
MikeHenson
ok thanks....then tell me this.  If I can only have 1 layout, is there any way to lock/freeze that layout so it stays the same, even though I switch back to the data layout? I would like to set my view and zoom the way I like it and then switch back and forth. Thanks
it can be locked, but only at one view for one data frame, so you can go back to that data frame and do what you want.  If you want to do what you want when you want and have everything perfect...create an mxd for each map and then one for doing stuff...or migrate to pro, sooner rather than later.
KyleBalke__GISP
Mike you can always use a bookmark for each view...by doing so you can set each extent and return to it at anytime in your layout.
but...you can't bookmark a layout setup, if you are moving stuff on/off the layout page...only a dataframe view
