WebApp Builder Widget URL
3011
11-05-2015 05:13 AM
ToddHenry1
I have to change the URL of our Query widgets to point to a new ArcGIS for Server installation.   When I set a new URL all of the configuration settings disappear.  Is there a way to update the service URL without having to rebuild the widget?
RobertScheitlin__GISP
Todd,
   I'd it is just the irk that changes then I would just go into the query widget.json file and update the irk directly in the json using some text editor. This will work fine as long as the fields have not changed at all (I.e. Field name).
ToddHenry1
Robert,
Thanks for the help.  I neglected to mention that I'm using WebApp Builder that is hosted by ArcGIS online.  Would I still be able to access that .json file?
Todd,
   unfortunately not.
